E1 R2 - call setup and troubleshooting
dcobra
Router: Cisco 3725
IOS Version: 12.4(10a)
IOS image loaded: "flash:c3725-spservicesk9-mz.124-10a.bin"
Sometimes the E1 doesn't put channels in idle status, so it doesn't stay ready to receive next call.
I saw a lot of good information in CCO doc - E1 R2 Signaling Configuration and Troubleshooting, but the IOS version running in 3725 router do not have the same debugs from doc at URL:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800ad389.shtml
The carrier told us: therea are a bit ABCD error when the call has been diconnected (here in Brazil only bits CD matter to signaling).
When carrier sends "CLEAR_FORWARD" the router should be answer with CD=01 bits, but it never happens. In vision of carrier (Voice Service Provider).
Anybody knows how can I see the E1 signaling bits using IOS 12.4(10a)?
Darcio.
12 Replies 12
paolo bevilacqua
E1 R2 has got many bug fixes, could you upgrade to 12.4(13b) first and then if the problem continues we can look at your configuration any why the brazil country settings do not work ?
You could also try a latest 12.4T that is not less stable than 12.4 mainline.
gogasca
Level 10
Level 10
R2_Q421_CLR_BWD_OUT 0x0C /* 1100 */
Could you please post your controller config and cas-custom...make sure you use country defaults.
Once this is done, you can troubleshoot using:
'debug voip vtsp all'
'debug vpm signal'
'debug voice ccapi inout'
teodorgeorgiev
Level 4
Level 4
Does the "debug cas" command work?
Usually the AB bits matter. And Cisco give you the opportunity to change the CD bit values your gateway is sending.
People,
In this particular IOS version some debug haven't present like "debug cas". :-(
But after several customization test with carrier, we reach a good one configuration where the carrier is glad with all signaling information.
This gateway handles calls together a CCM (4.1(3)) cluster with 2 servers.
The end configuration for this case (connected to Brasil Telecom carrier) is:
! All configuration related with
! voice signaling
voice class h323 1
h225 timeout tcp establish 3
controller E1 1/3
framing NO-CRC4
clock source line primary
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country brazil
release-guard-time 500
category 2
answer-signal group-b 1
ani-digits min 7 max 10
description CONNECTED TO 0800
interface FastEthernet0/0
description SOURCE INTERFACE TO CCM H323-GTW
ip address 10.15.4.16 255.255.255.0
no keepalive
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.15.4.16
voice-port 1/3:1
no vad
no comfort-noise
cptone BR
description 0800
dial-peer voice 800 pots
incoming called-number 912
direct-inward-dial
port 1/3:1
dial-peer voice 801 voip
destination-pattern 912
preference 1
session target ipv4:10.15.16.17
dtmf-relay h245-alphanumeric
dial-peer voice 802 voip
preference 2
session target ipv4:10.15.16.16
Thanks for all for support, and I HTH somebody in future connections with Brasil Telecom carrier.
cheers.
Darcio.
P.S.: If this configuration sample was helpful, don't forget rate this post, please!
Good info, thanks!
hi, y need help for incoming calls, for e1 in mexico i try receive but not
work the tone is busy, always i try configuring dial-peer for incoming
calls but not work. The outgoing calls work fine.
controller E1 0/0/0
framing NO-CRC4
clock source internal
ds0-group 1 timeslots 1-12 type r2-digital r2-compelled ani
cas-custom 1
country telmex use-defaults
category 2
description """ E1 VOICE """
voice-port 0/0/0:1
cptone MX
dial-peer voice 21 pots
description local
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 3
destination-pattern 9.......
direct-inward-dial
port 0/0/0:1
forward-digits 7
dial-peer voice 1000 pots
description incoming calls
translation-profile incoming Incoming_Calls_5700
incoming called-number 467....
direct-inward-dial
port 0/0/0:1
forward-digits all
voice translation-rule 10
rule 2 /4050/ /124/
rule 2 /4051/ /124/
rule 3 /4052/ /124/
rule 4 /4053/ /124/
rule 5 /4054/ /124/
rule 6 /4055/ /124/
rule 7 /4056/ /124/
rule 8 /4057/ /124/
rule 9 /4058/ /124/
rule 10 /4059/ /124/
voice translation-profile Incoming_Calls_5700
translate called 10
thanks for your help
Hi nosferatus,
Are you still having problems with incoming dial-peers on E1 Telmex?
Hi remi-rezka.
thanks for you attention but the problem is Ok now
best regards.
hola nosferatus ,
I am glad you solved your issue. You know, I am setting up a trunk E1 with Telmex on my client's UC560. Telmex did not give us any parameters how to set up the trunk. I did it with "r2-compelled ani" and it works however all incoming calls from outside do not present caller ID (ANI), they appear as "Desconocido". Would you be kind to share your E1 configuration for Telmex service? Maybe I am also doing something wrong with the incoming dial-peer. It would be great if you could share your config.
Many thanks in advance.
Remi
hi Remi
this is my configuration
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
cas-custom 0
  country telmex
  category 2
dnis-digits min 1 max 16
  ani-digits min 0 max 10
  ani-timeout 1
  timer interdigit incoming 1000
  groupa-callerid-end
description """ E1 VOZ """
voice-port 0/0/0:0
cptone MX
translation-profile outgoing outgoing_calls
translate called 10
voice translation-profile outgoing_calls
translate calling 2
voice translation-rule 2
rule 1 /^9/ //
rule 1 /^4060/ /7000/
rule 2 /4050/ /6000/
dial-peer voice 200 pots
description Incoming
incoming called-number .
direct-inward-dial
dial-peer voice 201 pots
description Outgoing
destination-pattern 9T
port 0/0/0:0
(Y)
Hi nosferatus,
Thanks a lot for the config. Without having Telmex E1 parameters I came up with quite similar config to yours. I did the configuration and still no caller ID (ANI). Did you have similar problem while setting up the trunks? Is it possible Telmex is blocking ANI on our E1 service? Thanks for any suggestions.
