how can i build Hunt group ? ..... Hunt group ?????? ...... ??????
tareqrebhi
hello,
i have service prepaid calling card i configured Dial peer and every thing is ok.
One problem i have that only one session is available for all users.... i need to make an Hunt group.
what the command i shall use?
thank you for any helping.
BR,
paolo bevilacqua
actually unless you configure max-call there is no limit to the number of sessions a DP can support.
paolo bevilacqua
dear, thank you for help i did max-conn command before but i thought there is command for hunt group... no problem... now i have this issue:
i did at my AS5400:
VoiceGateway#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0xAF30 28D7 0x5543013C 7/0.6 1/13:0 *65523601 g711ulaw 287/1
0xB050 2A56 0x5543013C 7/0.7 5/9:4 *65855918 g711ulaw 0/1
0xB079 2AA0 0x5543013C 7/0.3 1/2:1 *65331605 g729r8 0/1
0xB0B6 2B04 0x5543013C 7/0.2 5/3:2 *65671445 g729r8 0/1
0xB0C7 2B21 0x5543013C 7/0.8 3/15:3 *65681018 g723r63 0/1
0xB0E9 2B54 0x5543013C 7/0.5 1/16:1 *777751690 g711ulaw 200/2
0xB0EF 2B64 0x5543013C 7/0.4 1/12:1 *7142823464 g711ulaw 200/1
Q1. what * means?
Q2.why just AS5400 shows 10 digits maximum?
Q3.how i can see all digits that i dialed?
Q4. for international calls 00xxxxxxxx i did not do Dial Peers or translation rules but the calls succeed and i can do international calls from AS5400 how this happens.just i have these commands:
translation-rule 1
Rule 1 ^1515#9627 7
Rule 2 ^4020#9622 2
Rule 3 ^4020#9623 3
Rule 5 ^05 5
Rule 6 ^06 6
Rule 7 ^07 7
Rule 8 ^02 2
dial-peer voice 1 pots
destination-pattern .T
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing called 1
port 7/0:D
any help please?
BR.
Hi, do "show voice call active" to see the complete information.
Then it's normal that you can call any number, as you have .T that catches anything.
Thanks for the appreciation and good luck!
