How Can I removed as ring froma voip phone
Hi Guys.
I got CME8.0. with IOS c2900-universalk9-mz.spa.151-1.XB.bin total 10 phones. is a site office.
3 extension 4177,4161,4162 with (phones 6961) ring at the same time. I want to just one phone to ring how can I disable the ring on the other 2 phones
maint ext is 4177(want to ring)
the other extensions are 4161 and 4162 (not to ring when a call coming to 4177).
I tried to just copy a new button set up from the config,but it didnt work .
I hope this maker sense
this is 4161 config
ephone-dn  61  octo-line
number 4161
label tony
description T Kenedy
name T Kenedy
call-forward busy 5999
call-forward noan 5999 timeout 20
Ephone 61
device-security-mode none
description Tony
mac-address 6400.F13A.7ED6
max-calls-per-button 1
username "tkennedy"
type 6961
buttons 1:61 2:77 3:80 4:81 (how can removed  2:77,3:80 and 3:81 and have only 1:61 only).
thanks guys
paolo bevilacqua
Same as removing any other command.
no button x:y
restart
paolo bevilacqua
no button x:y
restart
tahnsk Paolo
Thank you for the nice rating and good luck!
