How to route call from PSTN on voice gateway AS5400 with specific CIC
daneth.mean
Dear All,
HI expert, Is there anyway to route call from Mobile PSTN on specific CIC ( Example= cic:16 ) to AS5400 out to the world.
Here is My scenario:
Mobile Number --------> PSTN switch --------> PGW ( SS7 ) --------> AS 5400  ---------H323---------> call to  USA ( Terminating Gateway )
        CIC=16
Danet
Edit your incoming DialPlan and add a new rule for incoming mobile numbers.
This rule will use a new ResulSet.
In the ResulSet you must select a specific Route List.
The Route List will use a Route with a special trunk where you will define only one CIC.
Regards.
P.S. The creation procedure is in the opposite order (trunk -> trunk group -> Route -> Route List -> Resul Set -> Dial Plan).
Dear Daniele,
I might lost CD somewhere already when first product delivery.
Now are you using only with CLI mode.
Can you provide provision with CLI summary example ?
Best Regards,
Danet
