09-21-2008 04:34 AM
What are the platforms that support complete ITP functionality other than the c7600 series? According to my understanding, some 2800,7200 and 7300 series routers are there that can run as Signaling Gateways, however they are not full-fledged ITPs(i.e. no Core STP).
What are the possibilities of using a 65xx instead of 7600?
Many thanks for sharing your experiences in this regard.
11-11-2008 03:16 PM
I am using a 2811 as a STP and have passed MTP2/3 testing configured as STPs. Let me know if you want to discuss
01-29-2009 06:25 PM
This can help..
also feature depends on IOS
03-16-2009 01:04 PM
All other the ones you listed can run as full fledged STPs. It is all a matter of scaling. You would not want to use a smaller box as a core STP as it has smaller amount of TDM links that it can handle.
Also, it does not have the redundancy that most people would want in a core STP.
Also, the 65XX is not supported but the 75XX is.
12-29-2009 05:35 AM
Hello
Well,I'm running ITP on C2610XM,at least it keeps M2PA links operational.
Sincerely
