MQC IP RTP Header compression
tcherkon
Hello!
My 7206 is configured as follows (only essential lines given):
interface Serial5/1:0
ip address x.x.x.x 255.255.255.252
encapsulation ppp
ip route-cache flow
max-reserved-bandwidth 95
service-policy output policy1
policy-map policy1
class cm-VOICE
priority 512
compress header ip rtp
class class-default
fair-queue
random-detect
compress header ip tcp
c7206.1#sh policy-map int se 5/1:0 out class cm-VOICE
Serial5/1:0
Service-policy output: policy1
Class-map: cm-VOICE (match-any)
993857 packets, 146395791 bytes
5 minute offered rate 105000 bps, drop rate 0 bps
Match: ip dscp ef (46)
970530 packets, 144702909 bytes
5 minute rate 105000 bps
Match: ip rtp 16384 16383
23327 packets, 1692882 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 512 (kbps) Burst 12800 (Bytes)
(pkts matched/bytes matched) 246067/37464929
(total drops/bytes drops) 0/0
compress:
header ip rtp
UDP/RTP (compression off, IPHC, NON TCP)
Sent: 0 total, 0 compressed,
0 bytes saved, 0 bytes sent
rate 0 bps
I can see here that compression is OFF, and no headers are compressed. Why?
Thanks in advance!
Brandon Buffin
Make sure that cRTP is configured on the other end of the link as well.
Brandon
