05-15-2008 10:49 AM
Hi all,
I need help with a Cisco ATA 186. Our company has installed a analog intercom and since we are running a VOIP network, i had to hook the analog inetrcom through a ATA 186 and patched the ATA 186 into our network. Everything is working fine, however when you press the off hook button on the intercom, you only get a dial tone.
My question is: is there any way of telling call manager or the ATA to dial an extension immediately when the intercom goes off hook, instead of getting a dial tone? There is no key pad on the intercom so the user has no way of inputting any extensions.
What i would like to accomplish is to just assing a shared line on multiple phones so that when a user presses the intercom line, it automatically dials the shared line i have programmed into the phones.
Please help!! Thank you.
Solved! Go to Solution.
05-15-2008 12:26 PM
You can configure PLAR for the ATA186 port. Take a look at the following link.
Hope this helps. If so, please rate the post.
Brandon
05-15-2008 12:26 PM
Brandon
05-15-2008 02:29 PM
Brandon,
nice name btw :) I followed the instructions to the tee and it worked, it took a little configuring but it works as advertised. Thank you for your response and the link.
05-15-2008 12:32 PM
Hotline (PLAR) is possible on ata using H.323 with CCM.
05-19-2008 07:18 AM
Link isnt working.
05-27-2008 05:11 AM
Brandon,
You can simply remove /partner from the link and it should work. Try this one:
Hope this helps.
Brandon
