Use of components in Cisco PGW2200
S N
Hi All,
  We are using PGW2200 in signaling mode .. Kindly clarify the use of linkset , ss7route , ss7path , naspath , c7link etc and how all are interrelated and with one call flow eg.
Sathya.
Pl find the document which I created based on your query and this document will help you to understand the use of components, its interrelation.
Kindly rate if you find the document helpful.
https://supportforums.cisco.com/docs/DOC-13683
Thanks.
Hi ,
It was really helpful .
Thanks for your efforts
Sathya.
