Voice and data on Catalyst 2950C
tony.h
IOS:c2950-i6q4l2-mz.121-22.EA1.bin
Configuration:
interface FastEthernet0/2
description IP Phones&PCs
switchport mode access
switchport voice vlan 200
mls qos trust device cisco-phone
mls qos trust cos
no snmp trap link-status
auto qos voip cisco-phone
spanning-tree portfast
end
If I configure the phone to Vlan 200, the phone can pick up the DHCP address for phone.
The pc connected to phone can pick up DHCP address for data.
Could anyone please advise why and how?
Tony
6 Replies 6
Aaron Harrison
Tony
The switchport voice vlan 200 command instructs an IP phone that you plug into the port to work in VLAN 200 by a CDP exchange at startup... You shouldn't actually have to configure the VLAN on the phone yourself..
The PC attached to the phone will go into the normal vlan for the port which in this case will be 1 as it is left at default...
Basically the link between the phone and switch is a dot1q trunk.
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thank you for your reply. I try the following commands:
switchport mode trunk
end
The phone still picked up data vlan IP address.
IP-Helper has been configured and works on 3560 and 3750 where I use the following configuration:
mls qos
interface f0/2
sw mode acc
sw voice vlan 200
mls qos trust cos
Could you please provide a working configuration? Your help is really appreciated.
Tony
What does your trunk configuration look like on the 2950 and on the router that is connected to the 2950? Are you aloowing only certain VLAN's? How about if you configure a port on the 2950 to native VLAN of 200 and see if a PC connected to it gets an IP from VLAN200. What kind of link is between the 2950 and the other switch?
What do you see in your logs if you do
debug ip dhcp server events
debug ip dhcp server packet
The topology is as below:
IP Phone 7940<-->2950<---trunk--->3750<---(IP networks)-->CallManager
If I place the port under vlan 200, the phone works.
There is no problem with DHCP. It seems there is something missing or wrong.
markanthony
also remember that you still have to use the ip helper in your VLAN200 on the layer 3 switch if your DHCP server is not in there so that it can forward the request for the DHCP address.
Tony
I've just re-read your original post, I may see the problem now...
You say that if you put the port in access vlan 200 the phone works fine? Then your ip-helper/DHCP/other trunk ports must be set up OK.
On your original post, you said you had this config:
mls qos trust cos
Try this configuration but without the 'switchport mode access' - you can put in 'switchport mode dynamic auto' instead.
