voice on 2801 with VIC3-2FXS/DID
aleemuddin
Beginner
Beginner
hi,
VIC3-2FXS/DID which is update version of VIC2-2FXS is not function well although configuration is same as vic2-2fxs, I can able to dial and there is ring but after picking by receiver within seconds line get disconnected I can hardly hear hello**!! from otherside then it cuts. this is happening on both ports.
other details on this issue:
orignal card vic2-2fxs of 2801 was damage so i have to get new but same model is now out of sale & replacement is vic3-2fxs/did.
new card vic3-2fxs/did was not detected so I have to update IOS ipvoicek9mz.124-20T on 2801
copied same configuration (vic2-2fxs which was running smooth but using other version  IOS)
voice-port 0/0/0
input gain 7
cptone BR
timeouts call-disconnect 5
timeouts wait-release 5
voice-port 0/0/1
input gain 7
cptone BR
dial-peer voice 112 pots
destination-pattern 112
port 0/0/0
dial-peer voice 113 pots
destination-pattern 113
port 0/0/1
I notice when i tested sound card localy (hooking telephone sets on both ports) and if i dail number there is ring and sound is good no disconnects no issues atall but when router sends to branch and connects to telephone sets and dail the number from other branch it rings and disconnects after receving hello.
voip configuration (same config is working fine with vic2-2fxs)
class-map match-any REAL-ESTATE-VoIP
match access-group name MATCHING-VOICE-PACKETS
class-map match-any REAL-ESTATE-CALL-SIGNALING
match access-group 100
match access-group name VoIP-RTCP
class-map match-any KHARJ
match access-group name KHARJ
policy-map REAL-ESTATE-VoIP-POLICY
class REAL-ESTATE-VoIP
    priority 67
class REAL-ESTATE-CALL-SIGNALING
    bandwidth 8
class KHARJ
    shape average 150000
    bandwidth 150
class class-default
    fair-queue
     random-detect
ip access-list extended KHARJ
remark This Access list will match the ip traffic sourced from any to any
permit ip any any
ip access-list extended MATCHING-VOICE-PACKETS
permit udp any any range 16384 32767
ip access-list extended VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list extended VoIP-RTCP
access-list 100 permit tcp any eq 1720 any
access-list 100 permit tcp any any eq 1720
access-list 100 permit udp any eq 1719 any
access-list 100 permit udp any any eq 1719
end
paolo bevilacqua
Already discussed in another thread, please do not open duplicates.
Steven Holl
EDIT: Closing as dup.
