(1) UC560 and E911 with (2) companies
dmelo63
If I have (2) Customers in separate buildings (Same parent company) that will be tied together via a fiber connection.  Can I somehow use (1) US560 and somehow support them both if someone in the remote building dials 911?  Is there a Tenant function that would work to direct those calls out a specific extension which would have to be designated as the remote address?
Brandon Buffin
One way to do this would be to map 911 calls from the remote location phones to a particular outbound port. You would then setup the location information for this phone line to match the address of the remote office. See the following link for how to accomplish the port mapping.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Hope this helps.
Brandon
