8.6.5 Release Date
jniblack
Hi.  What is the anticipated release date for 8.6.5?
Thanks!  Jim
25 Replies 25
sanjsinh
Q2 of CY 2013.
Can phone firmware be upgraded on 8.6.4?  For instance, I would like to upgrade 69XX phone firmware to 9.3 from the 9.2 version that shipped with 8.6.4.
If this upgrade is possible, is this as simple as loading the cop file using the BE3000 Maintenance>Upgrade procedure and then restarting the BE3000?
Thx, Jim
Hi Jim,
Yes, firmware can be upgraded and the process is as simple as loading the cop file using upgrade procedure, then re-booting the BE3000.
Thanks, Blake
hector torres
Is there a site/link to information about what will be included in this release?  I have a suspicion and could guess but would prefer to see some sort of list.  thanks!
We have a list of features targeted for this release. As we get close to the release date, we will share that with the partner community.
isiconsultants
any updates on the release date for the BE3K to 8.6.5???  I have a client that would like to step up.
thanks,
Hector
It is still tracking early Q2 of CY13 for release.
Does early Q2 of CY13 mean April of 2013???
Hector
Any update on the release date as May 2013 approaches???
thanks!,
-Hector
We are  tracking Q2 of this calendar year for a release date. Will let you know an accurate date as we get close to it.
Hi sanjay,
Do you have information what feature and additional in BE3000 version 8.6.5 compared with version 8.6.4?
Best Regards,
Nanda Nurhadyan
Best Regards,
Nanda Nurhadyan
Any news on the 8.6.5 release date; should we expect end of June?
thanks,
Hector
Checking the site daily to see if 8.6.5 has been released.  hopefully it will be sooner than later
thanks!,
Hector
Should be end of this month or early August it will be available .
Chandra Mouli
