03-20-2013 07:02 PM - last edited on 03-25-2019 11:05 PM by ciscomoderator
Is there a top level SKU for adding phone licenses to a existing Business Edition setup?
I beleive the SKU for standard CUCM should also work for BE 6K as well.
L-CUCM-USR-LIC-ADD | Top Level Sku For Adding User License |
CM-RTU | Unified CM RTU claim certificate |
CUCM-PAK | Include PAK Auto-expanding PAK for CUCM |
CUCM-USR | Include PAK Auto-expanding User for CUCM |
LIC-CUCM-ESS-A | UC Manager Essential - Less than 1K Users |
LIC-CUCM-USR-A | Unified Communications Manager Enhanced Single User-Under 1K |
Please suggest.
Nirmal
Solved! Go to Solution.
03-21-2013 01:44 AM
Hi Nirmal,
Ok - for 8.6, then please use R-UNIFIED-CMBE6K as the top level part code.
Please refer to the BE6000 Ordering Guide - Section 4.3 (Page 19):
Use the Add-on users section of that part code.
Andy
04-02-2013 07:12 AM
Hi Nirmal,
BE works the sames as UCM with DLUs in the backend to enable licensing.
For R-UNIFIED vs. L-CM-DL SKUs,
- if the customer has 7.1 and earlier release, then they should be purchasing DLUs.
- if the customer has 7.1.5 and newer release, then they should be purchasing UCLs (R-UNIFIED) to keep the licensing model consistent for services and support.
Blake
03-20-2013 11:19 PM
For version 9, you can use R-CBE6K-K9 to order additional user licenses.
Andy
03-20-2013 11:54 PM
Hi Andy,
Thanks for looking into this.
Can I not use L-CUCM-USR-LIC-ADD part code? I beleive evry license we order would ultimately get converted to DLUs at the backend so Is it really necessary to slect part code for BE6K.
Whats the difference?
Need clarification.
Nirmal
03-21-2013 01:44 AM
Hi Nirmal,
Andy
03-22-2013 03:42 AM
Andy,
I just came to know that the client is running Business Edition software on MCS 7828 server, so it has to be BE5K.
In that case as per the ordering guide I should be using "R-UNIFIED-CMBE5K" part code for ordering add-on licenses but I beleive this is already EOS.
Can I still use BE5K part code here or I will have to migrate the customer to BE6K platform and upgrade all the licenses as well?
What options do I have here?
Nirmal
03-22-2013 06:50 AM
Hi Nirmal,
Add-on licenses for the BE5K are still orderable. Please use R-UNIFIED-CMBE5K to order addition licenses for add on users. Please note the UNIFIED-CMBE5K with the starter bundles are already EOS and can't be ordered.
Blake
04-01-2013 10:39 PM
Hi Blake,
Thanks a lot for confirmation.
Please let me know if we can use L-CM-DL-100= to add licenses to BE5K server for ip phones?
End client is asking for "L-CM-DL-100=" instead of "R-UNIFIED-CMBE5K".
Will there be any issue if we get this part code?
Nirmal
04-02-2013 02:44 AM
My customer has MCS 7828 H3 server with CUCM version 7.1.2.
Please suggest.
Nirmal
04-02-2013 06:31 AM
Hi Nirmal,
If the customer is 7.1 or older, the DLU add-on SKUs are valid for ordering additional licensing.
Blake
04-02-2013 06:57 AM
Blake,
So you are saying both "R-UNIFIED-CMBE5K" and "L-CM-DL-100=" part codes are valid if we have to order addon licenses for Business Edition server running call manager version 7.1.2 ?
I am confirming this beacuse my local Cisco SE told me that "L-CM-DL-100=" part code will not work and aksed us to go with other one.
Can you also clarify how the licenses work in the backend for BE servers, I beleive it should be same as call manager where you associate license mac with the file and the uploaded license gets converted into DLUs for phones to use?
I am really confused here, please help.
Nirmal
04-02-2013 07:12 AM
Hi Nirmal,
Blake
04-03-2013 11:22 AM
Blake,
Thanks for the clarification.
Nirmal
