Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
                   Hello,I registered a SPA122 on a SV8100 NEC pbx; the device is correctly registered and can make outgoing calls but it can't receive any calls...The caller receives the busy tone when calls SPA phone number.If I register a CISCO IP...
Brand new device (purchased from Amazon)Firmware upgraded to 1.4.1SR1(002)Factory resetProfile_Rule set using /admin/resync?http://server/init.cfgSome parameters are set including Profile_Rule_B, Profile_Rule_C, etc (all configs pasted below)Device s...
kp1893612 by Level 1
  • 1478 Views
  • 3 replies
Hello! I have the following dial plan in a Cisco ATA with Router SPA122: (99999 | *xx*xxxxxxxxx.# | *xx*xxxxxxxxx.*xx# | *xx*xx# | #xx# | <:0224>[2-9]xxxx. | <:0224>1[02-9]xxx. | xxxxxxxxxx.) Is there a way to modify it to avoid the following?:1. Int...
