BE6K Partner Playbook
skilambi
This link seems to be broken.
Go here
https://communities.cisco.com/docs/DOC-30850
Then go down the list and click on Proposal Generator Tool under Proposing section
Click on the Proposal Generator Tool and the link is broken. How do we get access?
Srini
panjwani80
Level 5
Level 5
Proposal Generator Tool isn't working for me either. Access Forbidden error message
Can someone from Cisco look into this please?
Sorry guys, after further research it appears the tool has been decomissioned. Check out the downloadable proposals in the "Steps to Success" at http://tools.cisco.com/s2s/spotlight.do?method=spotlightDetails&spotlightId=25 .
Sorry everyone, here is the latest link to the Steps to Success section on Midmarket and the collab steps:
http://tools.cisco.com/s2s/ViewProcessFlow.do?method=browsePhasePage&phaseKeyId=155|EXT-AS-122673|EXT-AS-122699&techName=UnifiedCommunications&techMSOrder=2&phaseCounter=2&componentCounter=1&languageId=1&archName=Collaboration&parentTecName=null
Looks like it changed, you will still need your CCO login
MA
Message was edited by: Michael Allen
The link in mikeall reply from Oct 16 is also not working as of Nov 23rd 2012. Mike, if you see this can you correct or provide other direction?
I updated the post above, sorry there was a few changes to the program.
MA
