Bug in the latest spa3XX-5XXG phone firmware 7.5.6 - Can not transfer anonymous calls
william Jin
Beginner
Beginner
Hi support,
I just found a bug in the latest phone firmware 7.5.6.
Platform:
Linux Debian Wheezy
Asterisk 11.7
FreePBX 2.11
Affected Cisco phone model: SPA504G and SPA514G(I only tested these two models)
The issue is when there is an incoming call with anonymous caller id, after picking up the call, the xfer and bxfer softkeys are missing. On the first page, only conf softkey(3rd place out of four softkeys). After pressing the right arrow, it's redial, dir, blank(used to be bxfer) and dnd.
TS has been done.
Tested with other phones brand, yealink, snom and mitel, all working.
Tested with firmware 7.5.5b, all working.
Tested with latest firmware 7.5.6, xfer and bxfer softkeys are missing.
I read the firmware upgrade note of 7.5.6 and found below:
CSCuh25063 The SPA5x5 phone has the ability to hide Xfer/Bxfer softKeys after initial network configuration.
Maybe it's related? pure guess. Does that mean we should have the ability to un-hide Xfer/Bxfer softkeys? HOW?
I am not requesting to fix this as soon as possible. My customers are happy after downgrading to 7.5.5b. But if it can be fixed in the next available firmware, that would be great.
William Jin
2 Accepted Solutions
Shilpa Gaddikoppula
Hi All,
This issue has been addressed via CDET CSCuq18187    SPA5x5, SPA525G2, SPA30X: 7.5.6 - Cannot transfer anonymous calls. Our Engineering Team has built an ES image on top of 7.5.6 with this fix. Official GA release with the fix will be 7.5.7. Dev Test Team is currently performing regression tests on the ES image. The image will be available later this Month. Customers who are interested to use the ES image can contact SBSC for receiving the ES image.
Hello Ryan,
Firmware 7.5.7 has been scheduled for late Feb 2015. If someone needs an immediate fix for this issue, we have an Engineering Special which is based on 7.5.6a.
Shilpa
30 Replies 30
Dan Lukes
Advocate
Advocate
I'm not so happy with it as pre-7.5.6 firmware have severe security issue ...
jimvman
Beginner
Beginner
I downloaded  the latest 7.5.6 firmware as well.  After downloading and extracting Symantec A/V found them to have a Trojan and quarantined the .exe files in the zipfile.  I'm not messing with this version until Cisco verifies the files to be clean.
I'm almost sure its false positive.
The program is very simple and can be inspected by eye and good disassembler within few minutes. I did it.
Well, I'm trusting myself more than an anonymous Cisco employee, but you may consider Cisco's opinion more relevant of course.
OK, Thanks was a bit worried because I have several older versions on the same machine without an issue.
Jim
You may consider *.bin style upgrade. I'm doing no executable style of upgrade, so I'm not in risk ...
peter00073
Beginner
Beginner
Same here! 7.5.6 firmware SPA502G and SPA504G
anonymous calls -> ONLY CONF button occurs
tech
Beginner
Beginner
Hi, we've created a fake caller id when there was none or anonymous using Asterisk. We can transfer those calls again.
Can I ask what Asterisk command you used to do this?
It depend on Asterisk version. For example:
same => n,Set(CALLERID(name)="something")
same => n,Set(CALLERID(num)="something")
Thanks Dan, it's more the "if" part of the asterisk rule I was looking for.
Test for empty CALLERID(num):
same  =>   n,GotoIf($["${CALLERID(num)}" != ""]?next)
same  =>   n(next),...
But it may not be possible to blindly follow other's advice.
In my case the anonymous call can't be recognized by CALLERID(num) but CALLERID(num-pres) needs to be examined instead.
Exact conditional depends on overall concept of your's extensions.conf, so we can't tell you how you can detect anonymous call in your's particular case.
Note we are off-topic a lot in this thread. You should ask further Asterisk-related question in a forum dedicated to Asterisk support.
Thanks! I got this working using:
  exten => UsSales,n,GotoIf($["${CALLERID(num)}" != "Anonymous"]?notanonymous)
  exten => UsSales,n,Set(CALLERID(num)=no number sent)
  exten => UsSales,n(notanonymous),...
Glad to hear.
Rate useful advices. It will help others to found solution.
Shilpa Gaddikoppula
Hi All,
Recognize Your Peers
