03-06-2013 01:07 AM - edited 03-21-2019 07:03 AM
I've installed on Office 2013, Windows 7 x64 and I'm getting an error: The program can't start because ccSIPoid.dll is missing from your computer.
Also, the installer never seems to finish. It puts the icon on my desktop, but then minimises to the tray and never disappears, like it's still installing?
Help!
03-06-2013 04:45 PM
Office 2013 is NOT compatible.
UC540 system with 8.6.1 Software Pack
03-07-2013 03:53 AM
I don't actually need to use the Outlook integration.
I would like to use the TAPI plugin, which speaks to our Connectwise helpdesk application for click to call.
Can I do this with another plugin, or perhaps a generic TAPI app?
03-10-2013 01:20 AM
I've never tried myself, but chances are that with a manual installation and some amount of hacking, you can get at least the TSP driver to run. You would study how that works on a supported OS, then try to replicate under Win 8.
04-11-2013 01:58 AM
I have this issue on a user with Windows 7 Home Premium 64 bit with Outlook 2010 32 bit. Is Home Premium supported? Doesn't mention it in the software Release note.
Any suggestions what we can try??
(Also encountered the same error on the same site with Windows 8 64 bit with Outlook 2010 32 bit but I see Windows 8 isn't supported yet!)
