Can I rescue my PAP2T-NA?
Tech.Joseph
I have got a Linksys PAP2T-NA second hand. (V1) But it seems a DOA.
When I power it up, the Power-Led lights up amber for a short moment. Then, it is full-lit red, while also Phone 1 and Phone 2 are lighting up blue. The ethernet led doesn't flash at all. After that, all lights go off.
I have allready done 2 hardware resets with it, but doesn't change anything.
I tried to connect my Ethernet cable to the device, but my NIC's lights don't even light up. So I can conclude that the ethernetport is pretty dead. Also, it does't accept an DHCP-Offer from my router, nor request one.
Trying to get in the IVR menu (****) doesn't help neither. I don't get a dail tone, and the charachters aren't even dailed.
Is there a method to wake up this device? If needed, I have a JTAG cable, a soldering iron, and a screwdriver at hand.
Thanks for all the thoughts!
According to explanation of the document "ATA_Installation_Blink_Patterns_OCt09" I think that your case can be described by the last scenario: bad ethernet hardware port, RMA unit.
See the link https://supportforums.cisco.com/docs/DOC-9901
Check the warranty and open an RMA.
Regards.
This thing is allready out of warranty. That is why I ask it here.
Hi NobodyKnows,
It could be that the power supply is of the wrong rating... [try using 2A supply if you have one available]
I've seen similar behavior in my lab when I mix up supplies and use a less than 2A supply [they all look very similar]
Patrick
Hi Patrick,
Unfortunately, I only have one Linksys adapter lying around here, and that was the one that shipped with it.
I will look for an other power supply, providing 2A and I will let you know. (Although the current psu does provide 2A as well)
