11-23-2010 02:49 PM - edited 03-21-2019 03:18 AM
When trying to install the Cisco Smart Toolbar (in order to restore TAPI to my LOB application), I get the following error upon launching the installer;
"Cisco Smart Call Connector Server is detected in your system. This product is not compatible with smartcall connector server."
I have uninstalled everything Cisco I can find from the control panel, except the CCA. I then deleted all the folders from c:\Program Files, rebooted and I still get the install error above. It might be residue in the registry - that's my only guess.
Or is it something in the UC-540 or in the CCA?
Any ideas appreciated.
11-24-2010 08:02 AM
Hi Brook;
I am escalating your issue. Stay tuned.
Regards;
Alberto
11-24-2010 08:43 AM
Hi Brook,
Would you please go to google, search and download Microsoft Windows Installer Cleanup Utility.exe and try to run this app to remove SCC Server?
Hope this helps. If needed, I can setup a webEx session and work with you to get this resolved. Please provide me your email address and when would be good for you, then I'll forward you a webEx session.
CallConnector Team
