07-16-2013 11:51 AM - edited 03-21-2019 07:34 AM
We came in today to a busy signal when accessing any voicemail. Calls come in and out just fine. when doing a "sh voice call summary" we get these lines. I'm guessing the S_SETUP_FAIL is related to the voicemail going down.
Cisco Unity Express 8.0.2
IOS: 15.0(1)XA3
PORT CODEC VAD VTSP STATE VPM STATE
0/0/0 - - - FXSLS_ONHOOK
0/0/1 - - - FXSLS_ONHOOK
0/0/2 - - - FXSLS_ONHOOK
0/0/3 - - - FXSLS_ONHOOK
0/1/0 - - - FXOLS_ONHOOK
0/1/1 g711ulaw n S_SETUP_FAIL FXOLS_ONHOOK
0/1/2 g711ulaw n S_SETUP_FAIL FXOLS_ONHOOK
0/1/3 g711ulaw n S_SETUP_FAIL FXOLS_ONHOOK
sh ver
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA3 a, SBTG Special
Small Business Support: http://www.cisco.com/go/smallbizhelp
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 08-Jun-10 13:40 by SBTG
ROM: System Bootstrap, Version 12.4(11r)XW, RELEASE SOFTWARE (fc1)
Kidane-UC520-Main uptime is 4 weeks, 1 day, 16 minutes
System restarted at 11:21:30 MST Mon Jun 17 2013
System image file is "flash:uc500-advipservicesk9-mz.150-1.XA3a"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco UC520-8U-4FXO-K9 (MPC8358) processor (revision 0x202) with 249856K/12288K bytes of memory.
Processor board ID XXXXXXXXXX
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
14 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Well I logged in to Service module integrated-service-engine and see a continuous cycle of bootups with the following being displayed. Can someone provide some advice on what I should do in order to remedy this and fix the voicemail? Is there a block on the flash thats bad so it can't complete correctly?
thanks for the help
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.16 11:16:40 =~=~=~=~=~=~=~=~=~=~=~=
boot disk
kern_sz: 1128866
bl_boot_cf_cmd root=/dev/hda1 install_root=ide ro plat=freddo
## Booting image at 04000000 ...
Image Name: Linux-2.6.22-cisco-freddo
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 1128802 Bytes = 1.1 MB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Linux version 2.6.22.10-vs2.2.0.5-cisco-freddo (drodrig@fndn-bld-system1) (gcc version 4.2.2) #1 Wed Jun 9 18:44:37 PDT 2010
Zone PFN ranges:
DMA 0 -> 131072
Normal 131072 -> 131072
early_node_map[1] active PFN ranges
0: 0 -> 131072
Built 1 zonelists. Total pages: 130048
Kernel command line: root=/dev/hda1 install_root=ide ro plat=freddo
Platform: ise
IPIC (128 IRQ sources, 8 External IRQs) at fe000700
PID hash table entries: 2048 (order: 11, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 515840k available (1756k kernel code, 516k data, 92k init, 0k highmem)
in atrace_init
log_head: h: 0, t: 22320, l: 0, w: 0, s: 1047488
Using existing trace log
Mount-cache hash table entries: 512
NET: Registered protocol family 16
Generic PHY: Registered new driver
SCSI subsystem initialized
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Cisco ContentEngine Flash Driver Version 0.03
ceflash: Can't register misc device <NULL>
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xe0004500 (irq = 9) is a 16550A
serial8250.0: ttyS1 at MMIO 0xe0004600 (irq = 10) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize
Gianfar MII Bus: probed
eth0: Gianfar Ethernet Controller Version 1.2, 00:1b:58:e4:ea:7e
eth0: Running with NAPI enabled
eth0: 256/256 RX/TX BD ring size
eth1: Gianfar Ethernet Controller Version 1.2, 00:1b:58:e4:ea:7f
eth1: Running with NAPI enabled
eth1: 256/256 RX/TX BD ring size
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
hda: probing with STATUS(0x50) instead of ALTSTATUS(0x0a)
hda: STI Flash 7.4.2, CFA DISK drive
ide0 at 0xe1000000-0xe1000007,0xe100280d on irq 17
hda: max request size: 128KiB
hda: 2001888 sectors (1024 MB), CHS=1986/16/63
hda: cache flushes not supported
hda: hda1 hda2
i2c /dev entries driver
NET: Registered protocol family 26
TCP cubic registered
NET: Registered protocol family 17
ReiserFS: hda1: found reiserfs format "3.6" with standard journal
ReiserFS: hda1: using ordered data mode
ReiserFS: hda1: journal params: device hda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda1: checking transaction log (hda1)
ReiserFS: hda1: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Freeing unused kernel memory: 92k init
Cisco init
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
reiser root fs ...
Reiserfs super block in block 16 on 0x0 of format 3.6 with standard journal
Blocks (total/free): 248976/146982 by 4096 bytes
Filesystem is clean
Filesystem seems mounted read-only. Skipping journal replay.
Checking internal tree..finished
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
Welcome to [1;31mCisco [0;39m Service Engine
Setting the system time from system log
Tue Jun 11 05:15:00 MST 2013
********** rc.aesop ****************
Populating resource values from /etc/freddo_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/freddo_rsrc_file
Processing manifests . . . . . . . . . . . . complete
==> Management interface is eth0
Serial Number:
INIT: Entering runlevel: 2
********** rc.post_install ****************
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
STARTED: ntp_startup.sh
STARTED: LDAP_startup.sh
STARTED: SQL_startup.sh
STARTED: dwnldr_startup.sh
STARTED: HTTP_startup.sh
STARTED: probe
STARTED: superthread_startup.sh
STARTED: /usr/wfavvid/run-wfengine.sh
STARTED: /usr/bin/launch_ums.sh
Buffer I/O error on device hda1, logical block 69478
hda: no DRQ after issuing MULTWRITE
hda: drive not ready for command
Buffer I/O error on device hda1, logical block 3947
Buffer I/O error on device hda1, logical block 3948
Buffer I/O error on device hda1, logical block 3949
Buffer I/O error on device hda1, logical block 3950
Buffer I/O error on device hda1, logical block 3951
Buffer I/O error on device hda1, logical block 3952
Buffer I/O error on device hda1, logical block 3953
Buffer I/O error on device hda1, logical block 3954
Buffer I/O error on device hda1, logical block 3955
REISERFS: abort (device hda1): Journal write error in flush_commit_list
REISERFS: Aborting journal for filesystem on hda1
Jun 11 05:17:55 localhost kernel: REISERFS: abort (device hda1): Journal write error in flush_commit_list
Jun 11 05:17:55 localhost kernel: REISERFS: Aborting journal for filesystem on hda1
Waiting 1 ...Buffer I/O error on device hda1, logical block 69457
Waiting 5 ...MONITOR EXITING...
SAVE TRACE BUFFER
/bin/startup.sh: line 255: /usr/bin/atr_buf_save: Input/output error
Jun 11 05:18:02 localhost err_handler: CRASH appsServices startup startup.sh System has crashed. The trace buffer information is stored in the file "atrace_save.log". You can upload the file using "copy log" command
Waiting 12 ...Buffer I/O error on device hda1, logical block 32770
Buffer I/O error on device hda1, logical block 33320
INIT: cannot execute "/etc/rc.d/rc.reboot"
INIT: no more processes left in this runlevel
Buffer I/O error on device hda1, logical block 164720
07-16-2013 07:55 PM
You need to update IOS.
For CUE VM, you will need a new CF card, and re-install software as well.
07-16-2013 08:33 PM
Can I use any compact flash card for this? can I get something like this?
http://www.amazon.com/Sandisk-512MB-Compact-Flash-SDCFJ-512/dp/B001LGAKTS/ref=pd_sim_e_3
I guess the other big questions are: is there a guide for doing the re-install of CUE and CME after a bad compact flash card occurs?
07-16-2013 10:43 PM
Any good brand will work.
Read the CUE documentation for fresh installation using "installer image".
02-28-2014 03:52 PM
Hi Paolo,
My CUE CF card was broken, I bought new and want to install CUE software on it
But it seems that CUE CF card was format with reiserfs filesystem and have 02 partitions
CUE Bootloader does not have format tool and unable to mount the CF card with FAT16 format
Please advise how to format CUE CF Card
Thank you
Tom
02-28-2014 06:12 PM
Tom,
Are you sure the CUE CF that came with the unit was broken? I ended up fixing mine after doing a boot helper fresh load. I had no backup so this was my only option to restore CUE. You sound like you are another step back, because the flash is brand new. I still was able to bootup IOS and the startup-config loaded. The flash didn't need to be replaced.
Did you make sure the flash you got was cisco certified. there's only certain ones that work. I never had to go down that path. I did the boot helper load and this fixed my flash io block issues you see above.
So if your old flash is gone try this to get it to a working state where the ios is bootable and your startup-config is also loading, than perform the CUE installation
The ideal method to format the flash is by using the "format flash:" command from inside the UC500 Command Line Interface (CLI). In your case, since the UC500 won't even boot, your best option is to:
1) Format it using FAT in Windows, and move the IOS image plus the default configuration to the flash.You can get the latest 7.0.3 ZIP bundle from:
https://supportforums.cisco.com/docs/DOC-9829
IOS is a ".bin" file and default config a ".cfg" that will depend on your UC500 model. They are easily identifiable.
2) Re-insert the flash in the UC500 and reboot.
3) Once you get the system up and running with the IOS image, do a "copy flash:UC500XXXX.cfg startup-config" via the console (use HyperTeminal 9600, 8, N, 1 username/password = cisco/cisco. Enter enable mode by typing "enable" before doing the copy command)
4) Reboot the UC500 one more time.
5) perform CUE boot helper installation
02-28-2014 07:00 PM
Hi Jesse,
My UC520 is still running, but CUE module is not working because of CF card.
I bought the Kinston CF card 4G, and if I use to replace CF Card 128M of UC520, the UC520 is booting OK with fat16 format
But putting it in CUE CF slot, the CUE couldn't mount the file system, and as I investigated the CF Card for CUE seem to be formated with different type (reiserfs linux file system)
so CUE boot helper installation could not help, the still error mounting file system under boot, and with boot helper the CUE seems able to connect to TFTP server but could not write to CF card
I have tried the things you said but without success.
So Cisco support should have special tool to format CUE CF card, and I need help regarding it
Tom
02-28-2014 07:12 PM
That tool you speak of might not exist. The formatting of the device occurs during the install. so after you setup the tftp sever with the configuration files from the guide I listed above what happens after this part?
The Ethernet interface is internal. Enter cue-installer.2.0.1 for the default helper image. Ensure that the default boot is always disk, the default boot loader is always primary, and the Ethernet interface is always set to internal.
ServicesEngine boot-loader>config
IP Address [14.80.227.141] >14.80.227.141
Subnet mask [255.255.255.0] >255.255.255.0
TFTP server [14.80.227.128] >14.80.227.128
Gateway [14.80.227.140] >14.80.227.140
Default Helper-file [cue-installer.2.0.1] >cue-installer.2.0.1
Ethernet interface [internal] >internal
Default Boot [disk] >disk
Default bootloader [primary|secondary] [primary] >primary
Updating flash with bootloader configuration
The system writes the information onto the Flash, and the ServicesEngine boot loader> prompt appears again.
Another Links you might find helpful
http://packetlife.net/blog/2009/nov/2/generic-compact-flash-cards-and-cisco/
03-02-2014 08:29 PM
Hi Jesse,
I have tried all thing you said and look at the links given by you but the problem is not solved.
The CUE Linux boot can recognized both card (1G and 4G) but unable to mount the files sytem
For the old broken Cisco CF card 1G, the CUE can see there were 02 particle, but in could not write and read because of CF card was failured
Here is log file
Cisco ServiceEngine Bootloader Version: 1.0.3
(Jul 6 2007 - 10:15:37) MPC83XX
Resetting devices ....Done.
mac address for internal ethernet 00:1b:8f:ac:15:fe
Please enter '***' to change boot configuration: ***
ServicesEngine Bootloader Version : 1.0.3
ServicesEngine boot-loader> >
Unknown command '>' - try 'help'
ServicesEngine boot-loader> boot disk
kern_sz: 1128866
Zone PFN ranges:
DMA 0 -> 131072
0: 0 -> 131072
Platform: ise
in atrace_init
log_head: h: 0, t: 0, l: 0, w: 0, s: 1047488
TCP reno registered
eth0: Gianfar Ethernet Controller Version 1.2, 00:1b:8f:ac:15:fe
eth1: Gianfar Ethernet Controller Version 1.2, 00:1b:8f:ac:15:ff
hda: hda1 hda2
hda: status error: status=0x51 { DriveReady SeekComplete Error }
hda: status error: error=0x05 { DriveStatusError AddrMarkNotFound }, CHS=1050/4/
5, sector=1058656
ide: failed opcode was: unknown
5, sector=1058656
5, sector=1058656
5, sector=1058656
ide0: reset: master: controlling MPU error
5, sector=1058656
5, sector=1058656
5, sector=1058656
5, sector=1058656
end_request: I/O error, dev hda, sector 1058656
Buffer I/O error on device hda1, logical block 131072
lost page write due to I/O error on hda1
end_request: I/O error, dev hda, sector 1060680
Buffer I/O error on device hda1, logical block 131325
end_request: I/O error, dev hda, sector 10208
end_request: I/O error, dev hda, sector 1064232
Buffer I/O error on device hda1, logical block 131769
ReiserFS: hda1: warning: journal-1226: REPLAY FAILURE, fsck required! buffer wri
te failed
ReiserFS: hda1: warning: Replay Failure, unable to mount
List of all partitions:
0300 1000944 hda driver: ide-disk
0301 995904 hda1
0302 5008 hda2
No filesystem could mount root, tried: reiserfs
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(3,1)
Rebooting in 180 seconds..
ServicesEngine boot-loader> boot helper
bl_boot_helper_cmd tftpboot 0x4000000 cue-installer.uc500.8.6.5
Using internal device
TFTP from server 192.168.10.201; our IP address is 10.1.10.1; sending through ga
teway 10.1.10.2
Filename 'cue-installer.uc500.8.6.5'.
Load address: 0x4000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
Usage:
boot
boot helper - boot helper using TFTP
boot disk - boot image using compact or usb flash as root filesystem
For the new CF Card 4G, the CUE Linux recognized it is 4G card, but could not find the ReiserFS file system to mount root
Log file:
kern_sz: 1128866
000594: Mar 3 04:15:24.226: %SYS-3-TIMERNEG: Cannot start timer (0x863E3CA8) wi
th negative offset (-5054264). -Process= "TTY Background", ipl= 0, pid= 41, -Tr
aceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z
0x813A87B0z 0x802BE3B0z 0x802C1050zOK
Zone PFN ranges:
DMA 0 -> 131072
0: 0 -> 131072
Platform: ise
in atrace_init
TCP reno registered
hda: probing with STATUS(0x50) instead of ALTSTATUS(0xaa)
hda: , CFA DISK drive
hda: 7847280 sectors (4017 MB) w/1KiB Cache, CHS=7785/16/63
hda:hda: set_multmode: status=0x51 { DriveReady SeekComplete Error }
hda: set_multmode: error=0x04 { DriveStatusError }
hda1
0300 3923640 hda driver: ide-disk
0301 3923104 hda1
When I tried boot helper with TFTP, the TFPT can receive the request from UC and send the data but didn't receive an acknowledge data so it failed to transfer file to CUE
Log from TFTP Server
Connection received from 10.1.10.1 on port 2920
Read request for file
OACK:
TIMEOUT while waiting for Ack block 0. file
So I wonder if it need to have CF Card from Cisco with its special format (file system type and partitions)?!
Thank for your help
Tuan
