Enhanced MoH - UC540/560
Alex Rae
Hi team,
Are there any plans to support Enhanced MoH on the UC500 platforms? Whereby multiple MoH sources can be referenced simultaneously for different departments.
Thanks.
c.holloway
I know I'm a little late to this discussion but you can already do this on a UC500 using MOH groups.  See the article below on configuring them.  It does require some familiarity with using the command line.  However I would say those skills are worth having as you can get so much more out of your PBX using the command line rather than the very limited CCA
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1022742
Steven DiStefano
Anna T (CCA PM) has this on the feature list so it's just a matter of prioritization.
c.holloway
