Help on Extension Mobility Please
Davy Ad
Hello All,
Could smeone please tell me ,"How to disable Extension Mobility on CME 8.0 and  to reboot all my Cisco IP Phones 7941"?
I have done "no voice logout-profile 1" on each phones , still i could not return to my formal setting.
I reset the phone with 123456789*0# ,but no result.
I would be glad on your support
David
8 Replies 8
Darren DeCroock
Level 4
Level 4
David,
You may need to give each phone a username and password, under the ephone.  And also make sure there is a button assignment for each ephone.  Then you many need to delete and recreate the CNF files.  Would need to see your config if it is still not working.
Thank you,
Darren
Thanks Darren ,
I was about to locate the problem with Extension Mobility ,with " no logout-profile " and  assign button to each phone .
But one of the IP Phone I want to reset factory setting is not working .
Could you please confirm, how long does it take for factory reset ? This Phone has been trying to get details from CME since 2 hours now.
DaK
Dak,
Not sure exactly how long to factory reset a 7941, but definitely less than 2 hours..  Maybe 5 minutes would be normal..
Thank you,
Darren
I checked it this morning still not set to Factory reset. Could You advice on what to do ?
Could you check this Extension Mobility id it is okay ?
   pin 1111
   user XXXX password YXYXYX
   number 2101
   number 2102
   number 2103
   number 2104
   number 2105
   number 2106
   speed-dial 1 2100 label "2100"
voice user-profile 1
   pin 1111
   user YYYYY password XYXYXY
   number 2101
   number 2102
   number 2103
   number 2104
   number 2105
   number 2106
ephone-dn  6
   number 1101 secondary 2100 no-reg both
   label line 1
   description Mr A - 2101
   name Mr A
   call-forward noan 904567789 timeout 15
ephone  1
  description A
  mac-address 001C.58xx.xxx.x.
  username Mr.A password AXXX
  fastdial 1 0049575844 name Home
  speed-dial 1 0049575844 label "Home"
  type 7971
  button  1:6
  pin 121234
  logout-profile 1
ephone-dn  7
  number 2102 no-reg both
  label line 1
  description Mr B - 2102
  name Mr B
  call-forward noan 903456789 timeout 1
ephone  2
  description MrB Desktop Phone
  mac-address 1xX.Xxx.ccx
  ephone-template 1
  type CIPC
  button  1:14
  logout-profile 1
ephone-dn  12
number 2106 no-reg both
label line 1
description Mr.F - 2106
name Mr.F
ephone  6
  description Mr.F
  mac-address 001B.XXX.xXXX
  ephone-template 1
  type 7941
  button  1:93
  night-service bell
  logout-profile 1
Hello Daren
   Hello All,
The  Cisco IP Phone C-7941G still the same since  24hours. I check switch and CME connected to IP Phone,  I received this error message
Re: %IP_SNMP-3-SOCKET: can't open UDP socketing
%IP_SNMP-3-SOCKET: can't open UDP socket on port 161
Davy,
I am not sure why your phone is not coming up, but I do not believe that it has anything to do with extension mobility.  Here is some information on configuring extension mobility though CLI, if you are not using CCA.  If you are using CCA, just edit that phone, and remove the extension mobility check box.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
Thank you,
Darren
It was a software problem and I have replaced it with another phone.
Cheers,
Hello Guys,
This is the right way to configure Extension Mobility (EM):
(1) First, do this on CME( config) mode
Ip http server
telephony-service
url authentication http:///CCMCIP/authentcate.asp
(2)
   user password <1111>
   number 5000 type normal
   speed-dial 1 5000 label 5000 ! >>>> This will be the number that shows on your IP Phone<<<<
(3) ..Depend on number of people in a group ,( If you have 10 people in a group ,you need 10 of User-profile)
   user < A> password   >>> as you want your password to be
   number 5001 type normal
voice user-profile 2
user   password
   number 5002 type normal
voice user-profile 3
user password
   number 5003 type normal
    exit
voice user-profile 4
user password
   number 5004 type normal
   exit
voice user-profile 5
user password !!!!>>>>>>Make sure the user name are not the same
   number 5005 type normal
    exit
voice user-profile 6
user password
   number  5006 type normal
   exit
(4) Assign logout-profile to each Ephones ( This must equal number User-profile)
ephone 1
logout-profile 1
ephone 2
logout-profile 1
ephone 3
logout-profile 1
ephone 4
logout-profile 1
ephone 5
logout-profile 1
ephone 6
logout-profile 1
Then save it you are Done !!!
DAK
