How to Activate Agent Log in & Log out password?
angelo castro
We have cisco uc500 system and we want to know if this system support the
ACD Agent Log in & Log out password?
Angelo
6 Replies 6
nalbert
Level 4
Level 4
Call Center functionlity is not available on UC500. You could need CCM with IPCC express.
You could use Basic ACD ( BACD) functionlity
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_1/administration_guide/cca_31_sbcs_admin_guide.pdf
Hi Navin X Albert
thank you for info..so you mean we need to upgrade to another higher model of cisco system?
In most cases, CME is perfectly fine for small call center.
Hi Paolo Bevilacqua,
up to how many agent can be used in CME?
angelo castro
Dear Mr. Nalbert,
This is Elvin Soh from Hogaiyota, and I am the senior programmer in Panasonic &
NEC Call Center.
How can I set-up a Cisco Call Center c/w ACD group with password-log-in/out and show in TAPI data, says 30-50 agents.
Do Cisco also provide Voice-Logger?
Elvin Soh
As above. Password login is not supported.
TAPI is not applicable
ephone-hunt can have up to 20 members.
Voice recorder is a separate product to be purchased from third party. Cisco does not make it.
