12-17-2009 10:28 AM - last edited on 03-25-2019 10:45 PM by ciscomoderator
I have a question about DSP resources.
I understand that for SIP trunking, the maximum amount of concurrent calls on a given SIP trunk depends on the amount of availiable ro allocated DSP resources available to that sip trunk. Is that correct?
Also, how can I determine the amount of DSP resources my system has available to both SIP truunking and Ad-Hoc conferencing, etc... ?
I currently have an 8 user UC520 with Meetme and Multi-party conferencing enabled.
More detailed specs are available if need be.
Thanks.
-Brian
Solved! Go to Solution.
12-18-2009 06:00 AM
Calls over a SIP trunk will invoke DSP resources only if made from a local FXS port, if transcoding is used, or if the SIP call joins a conference session.
Marcos
12-18-2009 05:45 AM
12-18-2009 05:57 AM
Hi Marcos,
Thanks.
So if I've read this correctly, calls recieved or placed over a SIP trunk by IP phones do not take up any DSP resources? And does the processing of a SIP trunk itself, i.e. establishing and maintaining the TRUNK, take up any DSP resources?
-Brian
12-18-2009 06:00 AM
Marcos
12-18-2009 12:21 PM
Thanks.
