when using port 8443 (example) for httpaccess page at http://192.168.140.8:8443/go to Wi-Fi (or bluetooth or..... )when you want to go back to Voice it links incorrectly to http://192.168.140.8/
Hello,I want to make calls from my Dect phone connected to the FXS port of the SPA3102 thru FXO port. The PSTN line is connected to the FXO port. I have added the plan "<#,:>xx.<:@gw0>" to the dial plan of Line 1. When i dial "#" and after hearind di...
Hello,now I wan't to try receiving faxes.I adjusted my SPA3102 with the HowTo from 3CX to work as an ATA device on the fax extension with 3CX. I can dail numbers and the other fax machine is answering and I can receive calls from other fax machines. ...
Hi all,I'm now working on the planning of an IP Telephony solution, now the customer is asking me about the max ammount of analog phones i can conect to a single physical line of a FXS port ot ATA or VG, since the actual solution allows them to conne...
Hopfully some one at Cisco will see this post.I am the proud owner of a spa3102 and registered with the support website, but still I do not get support !!!It seems tht the questions asked or problem reported are treated as non comital discussion even...
I tried to copy the original Cisco flash 128MB device to disk on two different WinXP Pro machines with both a Belkin and a Sony Flash reader/writer butthe process fails uniformly with a "blue screen freeze." The fault lies with fastfat.sys according...
I'm having a problem with a UC520 not routing properly.I currently have 3 vlans. The two created by the UC,plus an addition vlan for retail customers.I'm able to connect and route data between the data and the retail, but when I try to get to the int...
I have a UC520 that intermittantly gives a fast busy signal when picking up a phone to make a call. It will clear, then happen again. I have reset the box several times, but the issue comes back. Any ideas?
Somewhere over the course of upgrading a UC500 to 7.1.1ea the phoneloads and locale files for many of the phones (e.g., 7970, 7931) went missing. Where can I find them and how do I restore them? Following the instructions after the upgrade to updat...
If a company had 10 prompts, is there an easy way for them to access the prompts using the phone management? By easy, I mean when you are trying to find the one you want to rerecord, is there an easy way to get to prompt 9 or 10 without hitting the ...
I have a UC520 with a SIP Trunk and a Cable internet service (16mbps down, 2-3mbps up). I have noticed that at times users are downloading files from fast webservers, it will spike our bandwidth. This leads to poor quality voice calls, or voice calls...
UC520 install. Customer has a MAC environment. No email server. One user uses apple mail, the others have AOL email accounts. What should I recommend for the users to have voice mails sent to their email wihtout putitng in an email server.
i have a client who uses google apps and his email address is user@hiscompanyname.netI would like to know how i can setup the voicemail notification to the above email address? Not sure what smtrp settings to put in there.I have set it up earlier whe...
