Linksys Phone Adaptor PAP2-NS
p.clee
I have a Linksys PAP2-NS analogue phone adaptor.
The current firmware version is 3.1.8 (LS)
I am unable to find the model PAP2-NS in the cisco searches.
I have downloaded the lates firmware version 5.1.6 for PAP2T but when I try to update it gives me the message
UPGRADE FAILED: Version not matching
Can anyone assist pls
Rgds pete
6 Replies 6
Gajanan Pande
Where did you download the firmware from ?
Perhaps, a direct upgrade from 3.x to 5.x is not supported & might need an intermediate upgrade ( like in case of Cisco IP Phones ). By any chance do you have release notes kind of document for that 5.x firmware release?
If you could help me with the download URL, I should be able to locate the release note type of doc ( if any ) & confirm it for you.
GP.
Pls rate helpful posts !!
Thanks for the reply
I downloaded the version from:-
http://www.cisco.com/cisco/software/release.html?mdfid=282414114&softwareid=282463187&release=5.1.6
The TXT file included witrh the firmware update only indicated what fixes this version had
it did not indicate the need or not for direct update
Cheers
Pete
Is there a location for previous versions of firmware?
paolo bevilacqua
Wrong forum, try "small business, ATA and gateways". You can also move your post with the control panel on the right.
Thanks, like most things on this web site its difficult to navigate.
Are you able to assist me with my query?
Rgds
Peter
Hi Peter,
Please go here to check out the f/w that is available to download: http://www.cisco.com/cisco/software/navigator.html?mdfid=282414109
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
