09-22-2012 11:29 AM - edited 03-21-2019 06:19 AM
Team,
Does anyone know if the << backspace softkey is available to a 7960 or 7970 in a uc560? It is a really handy softkey but it doesn't seem to be an option under the softkey template. Is there a way to get that key on the phone?
Thank you
Paul
09-23-2012 05:13 AM
No, it is not available at all.
Will have to use 'arrow' keys only.
09-24-2012 06:51 AM
Hi Paolo,
Thanks for the reply. from what I have seen the arrow keys on the phones simply move the cursor allowing you to insert digits they don't erase the digit you may have mistyped. Am I missing soemthing here?
Paul
09-24-2012 02:21 PM
Hi Paul,
The << softkey is available under 7960 for sure when you are trying to enter a phone number to dial. It is available when you enter a digit. You do not have to change the template.
HTH,
Alex
*Please rate helpful posts
