MWI on Overlay button
mdube
Another question...
Is the MWI indicator supposed to work on an overlay button?
I want to have 2 or more shared lines on an overlay button and 1 (or more if possible) would have a voicemail.
Thanks!
P.S. There should be some kind of chat room so we could ask quick (and stupid) questions quickly
paolo bevilacqua
No, MWI will for only for the primary DN, not overlay ones.
David Trad
As Paolo said, it only works on a primary button...
However the work around I used was just purchase a SPA-500s so that way you can burn as many buttons as you want, considering that they are cheap and nearly seamless to integrate it is a worthy work around.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
mdube
Guys, not to contradict you, but I have a setup that is actually working right now, but I can't replicate it, so I guess it is a bug???
Here's the setup :
User1
SPA525G2
button 1 : Normal Extension 100 (VM enabled)
button 2 : Overlay extensions 200, 201
Fake Phone (I created a fake SPA509 phone with the following buttons)
SPA509
button 2 : Share Extension 200
button 3 : Share Extension 201 (VM enabled)
Hunt Group1
Calls 200 then forwards to voicemail directly on 201 (6201)
Believe it or not, the MWI on the second button of my SPA525G2 displays the envelope if I leave a message in VM 201.
Problem is, I can't access the GDM 201 from the User1 account as I guess, the 201 VM extension is not really "shared" with User1.
Is this a bug I ran into, or could this work?
What I am looking for is this :
User1
SPA525G2
button 2 : Overlay extensions 200, 201 (201 would have a VM)
button 3 : Overlay extensions 202, 203 (203 would have a VM)
button 4 : Overlay extensions 204, 205 (205 would have a VM)
Now, depending on the hunt group called, the User1 would know how to respond as every hunt group should be answered differently (some in french, some in english, some are customers, some are employees on the road). And user would be able to access the different VMs from his phone.
Would be neat to be able to actually distinguish on the phones what extension has been called, instead of simply adding extension 100 to every hunt group and have it flash for any calls, without knowing who's the caller.
Paolo, if this is something you can do with your scripts, then you will have an email from me soon enough!
It is possible to access the VM's in 201, 203, and 205 from the SPA525G phone.  There are a couple of different ways "that I can think" of to do this.
1. If you are using GDM's, you would just need to add the "user" for extension 100 to the GMD as a "member", and that would give them access.
2. The option I would use is to just dial VM directly from the button/VM you want to access.  The change that would need to be made is to just change the order of the Overlay extensions.
User1
SPA525G2
button 2 : Overlay extensions 201, 200 (201 would have a VM)
button 3 : Overlay extensions 203, 202 (203 would have a VM)
button 4 : Overlay extensions 205, 204 (205 would have a VM)
Then when one of the buttons has an envelope, just hit that button, and dial VM (399 by default).  It should then ask for the password for that VM box.
Thank you,
Darren
