# of Hunt groups associated with B-ACD and # Automated Attendants (AA) for UC560
jtreister
This reference (from public site) states (3) AA and (10) Hunt groups
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/reference_guide_c07-566560.html
This (harder to find document in supportforums) references (5) AA , but it does not reference (20) Hunt Groups. We understand from speaking with Cisco Partner Presales that the current firmware supports this, but we cannot find the published reference.
https://supportforums.cisco.com/docs/DOC-9656/
Brian Rapier
We are currently running 5 AA's on a 560 and have been doing so for a few months.
I cannot help with the hunt groups as we do not use them.
The 560 seems to support a bunch of features that can only be programmed using the CLI, I wish they would match the CCA up with these as it causes all sorts of issues if you do not remember what was configured using CLI vs CCA.
For instance our outgoing CLID was configured using the CLI as CCA only supports 15 entries where the CLI supports 100, which is great until someone opens the Outgoing CLID tab in the CCA and it over writes the CLI config.
paolo bevilacqua
That is correct.
You can have up to 10 hunt destinations in B-ACD/AA, and 20 ephone-hunt per system
