Problema de Configuracion UC560
                   El numero principal de la troncal es el  477 500 02 00  y son 20 Did´s ósea llegan hasta el 19.
controller E1 0/3/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-21 type r2-digital r2-compelled ani
cas-custom 0
  country telmex
  category 2
  answer-signal group-b 1
  caller-digits 4
  dnis-digits min 4 max 4
  dnis-complete
Tengo los telefonos logeados y no puedo hacer ni recibir llamadas, me pueden ayudar
6 Replies 6
Leonel2009
Checate esta liga me sirvio solo que no logro que recibir llamadas entrantes me dicen que todas las lineas se encuentran ocupadas
https://supportforums.cisco.com/thread/2120411
paolo bevilacqua
Start with "show controllers E1".
If that is OK, "debug vpm signal" with "term mon".
Este es el resultado.....no logro detectar el error..
No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (797 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 65 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
GrupoED#term mon
GrupoED#debug vpm signal
Voice Port Module signaling debugging is enabled
GrupoED#
000584: May 24 15:56:12.747: htsp_process_event: [0/3/0:0(10), R2_Q421_IDLE, E_DSP_SIG_0000]
000585: May 24 15:56:12.747: r2_q421_ic_seize(0/3/0:0(10)) Rx SEIZURE
000586: May 24 15:56:12.747: r2_reg_start_digit_collection(0/3/0:0(10))
000587: May 24 15:56:12.747: r2_q421_ic_seize(0/3/0:0(10)) Tx SEIZE ACK (with 100ms delay)vnm_dsp_set_sig_state:[R2 Q.421 0/3/0:0(10)] set signal state = 0x8vnm
_dsp_set_sig_state:[R2 Q.421 0/3/0:0(10)] set signal state = 0xC
000588: May 24 15:56:12.747: htsp_timer - 2000 msec
000589: May 24 15:56:12.747: r2_reg_process_event: [0/3/0:0(10), R2_REG_IDLE,E_R2_REG_START_COLLECTION(94)]
000590: May 24 15:56:12.747: r2_reg_start_collecting(0/3/0:0(10))
000591: May 24 15:56:12.747: r2_reg_timer_stop(0/3/0:0(10))
000592: May 24 15:56:12.751: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK]
000593: May 24 15:56:12.751: r2_q421_ic_setup(0/3/0:0(10)) E_HTSP_SETUP_ACK
000594: May 24 15:56:12.751: htsp_timer_stop
000595: May 24 15:56:12.751: r2_reg_offhook(0/3/0:0(10))
000596: May 24 15:56:12.751: r2_reg_process_event: [0/3/0:0(10), R2_REG_COLLECTING, E_R2_REG_OFFHOOK(95)]
000597: May 24 15:56:12.751: r2_reg_ic_offhook(0/3/0:0(10))
000598: May 24 15:56:12.751: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_IDLE R2 Got Event R2_START
000599: May 24 15:56:12.911: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='2'
000600: May 24 15:56:12.911: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_PRE_CALLERID R2 Got Event 2
000601: May 24 15:56:12.911: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '1'
000602: May 24 15:56:12.999: htsp_digit_ready(0/3/0:0(10)): Rx digit='#'
000603: May 24 15:56:12.999: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_PRE_CALLERID R2 Got Event R2_TONE_OFF
000604: May 24 15:56:12.999: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '#'
000605: May 24 15:56:13.079: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='8'
000606: May 24 15:56:13.079: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_PRE_CALLERID R2 Got Event 8
000607: May 24 15:56:13.079: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '1'
000608: May 24 15:56:13.159: htsp_digit_ready(0/3/0:0(10)): Rx digit='#'
000609: May 24 15:56:13.159: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000610: May 24 15:56:13.159: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '#'
000611: May 24 15:56:13.239: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='0'
000612: May 24 15:56:13.239: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_PRE_CALLERID R2 Got Event 10
000613: May 24 15:56:13.239: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '1'
000614: May 24 15:56:13.319: htsp_digit_ready(0/3/0:0(10)): Rx digit='#'
000615: May 24 15:56:13.319: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000616: May 24 15:56:13.319: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '#'
000617: May 24 15:56:13.399: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='0'
000618: May 24 15:56:13.399: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000619: May 24 15:56:13.399: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '6'
000620: May 24 15:56:13.479: htsp_digit_ready(0/3/0:0(10)): Rx digit='#'
000621: May 24 15:56:13.479: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_CALLERID R2 Got Event R2_TONE_OFF
000622: May 24 15:56:13.479: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '#'
000623: May 24 15:56:13.571: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='2'
000624: May 24 15:56:13.571: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_CALLERID R2 Got Event 2
000625: May 24 15:56:13.571: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '1'
000626: May 24 15:56:13.651: htsp_digit_ready(0/3/0:0(10)): Rx digit='#'
000627: May 24 15:56:13.651: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000628: May 24 15:56:13.651: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '#'
000629: May 24 15:56:13.739: htsp_digit_ready_up(0/3/0:0(10)): Rx digit='*'
000630: May 24 15:56:13.739: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_CALLERID R2 Got Event 15
000631: May 24 15:56:13.739: r2_reg_generate_digits(0/3/0:0(10)): Tx digit '4#'
000632: May 24 15:56:13.739: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
_IN_IDLE R2 Got Event R2_STOP
000633: May 24 15:56:13.739: r2_reg_event_proc(0/3/0:0(10)) ABORT_DIGIT_COLLECT
000634: May 24 15:56:13.739: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_WAIT_A
NSWER, E_R2_REG_ABORT_DIGIT_COLLECT]
000635: May 24 15:56:13.739: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_WAIT_A
NSWER, E_HTSP_RELEASE_REQ]
000636: May 24 15:56:13.739: r2_q421_ic_seize_release(0/3/0:0(10)) E_HTSP_RELEAS
E_REQ
000637: May 24 15:56:13.739: r2_q421_ic_seize_release(0/3/0:0(10)) Tx CLEAR BWDv
nm_dsp_set_sig_state:[R2 Q.421 0/3/0:0(10)] set signal state = 0xC
000638: May 24 15:56:13.739: r2_reg_channel_disconnected(0/3/0:0(10))
000639: May 24 15:56:13.739: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000640: May 24 15:56:13.739: htsp_timer - 200 msec
000641: May 24 15:56:13.743: r2_reg_process_event: [0/3/0:0(10), R2_REG_COLLECTI
NG, E_R2_REG_DISCONNECT(91)]
000642: May 24 15:56:13.743: r2_reg_disconnect_collect(0/3/0:0(10))
000643: May 24 15:56:13.743: r2_reg_timer_stop(0/3/0:0(10))
000644: May 24 15:56:13.939: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_CLR_BW
D, E_HTSP_EVENT_TIMER]
000645: May 24 15:56:13.939: r2_q421_ic_check_incoming_sig_status(0/3/0:0(10)) E
_TIMER_EVENT
000646: May 24 15:56:13.939: htsp_timer - 2000 msec
000647: May 24 15:56:13.939: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_CLR_BW
D, E_DSP_SIG_0000]
000648: May 24 15:56:13.999: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_CLR_BW
D, E_DSP_SIG_1000]
000649: May 24 15:56:13.999: r2_q421_ic_clr_bwd_idle(0/3/0:0(10)) Rx IDLE
000650: May 24 15:56:13.999: htsp_timer_stop
000651: May 24 15:56:13.999: htsp_timer - 2000 msec
000652: May 24 15:56:15.999: htsp_process_event: [0/3/0:0(10), R2_Q421_IC_CLR_FW
000653: May 24 15:56:15.999: htsp_timer_stop
000654: May 24 15:56:15.999: r2_q421_clr_fwd_idle(0/3/0:0(10)) Tx IDLEvnm_dsp_se
000655: May 24 15:56:15.999: r2_reg_channel_disconnected(0/3/0:0(10))
000656: May 24 15:56:15.999: r2_reg_process_event: [0/3/0:0(10), R2_REG_IDLE, E_
000657: May 24 15:56:15.999: r2_reg_disconnect_idle(0/3/0:0(10))
000658: May 24 15:56:15.999: R2 Incoming Voice(0/0): DSX (E1 0/3/0:9): STATE: R2
000659: May 24 15:56:15.999: r2_reg_timer_stop(0/3/0:0(10))
GrupoED#
You are receiving a call with 2800 as called number, you can ask telco why, or make so that it goes to some destination.
yes, the complete number is 3143312800 the last 4 digits is for DID, how do you get that digits? or where do you see them.
or how can i change to receive all digits?
You can, for example, number extensions as 28xx. Or manipulate the digits received.
However to make a professional configuration I recommend you engage a reputable consultant, or UC certified cisco partner.
The UC500 system is not designed to be configured by end user or anybody without experience.
