Push VLAN ID by DHCP for SPA
Giat
I have sitches with untagged data VLAN (68) and tagged VLAN for phones (70), but with no CDP or LLDP support. And some SPA112.
I want to push the VLAN ID 70 to the SPA112 by the DHCP.
I can't fix the value of the VLAN ID in the configuration file of the SPA because I use this file for an other network too
I didn't find any DHCP option or way to push the VLAN ID
balaji.bandi
what switches is this ? what is the configuration on the access port ?
what DHCP Server you using ?
BB
I use FlexNetwork 5130 Switch jg937a
I use a DHCP server Windows 7 server
Configuration of the access port :
interface GigabitEthernet1/0/37
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 70 tagged
port hybrid vlan 68 untagged
port hybridpvid vlan 68
stp edged-port
poe enable
interface Vlan-interface68
ip address 10.68.x.y 255.255.255.0
dhcp select relay
dhcp relay server-address @ip_DHCP
interface Vlan-interface70
ip address 10.70.x.y 255.255.255.0
dhcp select relay
Dan Lukes
There's no such option in DHCP recognized by SPA112.
