Question on the Service-module IP address
J W
I have what I hope is a simple question. I am in the process of configuring a UC560 and a UC540 for a 2-site company. Most of the administration will be done from site 1, which means I'll have to connect to site 2 using a VPN.
My question is, in order for CCA to work, does the service-module IP address have to be changed from its default 10.1.10.1 on both units? I was planning on making site 1 10.1.10.1 and site 2 10.1.20.1.
Does this fit in with best practice, or is this just over complicating things?
Changing the service-module IP is not supported apparently, as it requires CLI, so you will find that Cisco will pull the pin on any support entitlement.
19 Replies 19
David Trad
Hi Jared,
Simple answer for a simple question
Your assumption is correct, changing it to 10.1.20.1 is perfectly fine, it is consistent too
Just on a side note, please make sure that CCA correctly modifies the loopback address as well, I have seen it miss this from time-to-time so just have a quick peek on the UC-540 that it does this.... Although you don't have to worry about this on the UC-560 as it uses VLAN-90 instead of a loopback
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Thank you for your help. Not to complicate things, but where in CCA Would I go to change this? I see that there are some "web sites" that are hosted in the UC on on the IP address of the service module (10.1.10.1), as well as some ACL entries. Is there a clean way to change this in CCA without going through and making the changes with CLI?
Hi Jared,
Good question
Well my memory is getting bad in my old age (Or so my kids tell me ) but I believe this to be in the routing section, if you look in the navigation menu you should see it there (On the left hand side) and on the UC-560 you will see 3 VLAN's that are configurable, VLAN-1, VLAN-90 & VLAN-100 assuming they all remained as default, however on the UC-540 you will only see 2, VLAN-1 and VLAN-100 as the UC-540 uses loopbacks for the CUE module.
ON the UC-540 you will be changing VLAN-100 to the 10.1.20.X subnet, on the UC-560 it would be VLAN-90 (Well at least I think that's how it goes from memory ) Anyways once you see it, it should be self explanatory I hope
Cheers,
David.
Oh and VLAN100 is the voice VLAN, not the service-module (CUE) IP address on UC540. You can change VLAN100 to your heart's content, however as I said, changing the module IP is not supported (although accomplished easily with some CLI and CUE config changes).
You will need the UC Express certification to get CLI support, which is being retired, not to be replaced, so frankly not sure where a partner is to turn for CLI support now.
Hi Scott,
On a UC-560 you should be able to change the service module IP using CCA,
but not on a UC-540/520bas they do not use VLAN-90 they use the loop back
method and direct IP on the module.
However SBSC should be able to assist with the module change even when you
don't have UCX certification, if they don't initially then ask for it to be
escalated, and don't stop until it does get escalated to a manager who will
make the right decision.
Cheers,
David Trad
"Sent from my Acer Iconia A500"
On Jun 2, 2012 9:14 PM, "smproductions" <
Hi David,
You are right, i was mistakenly referring to the UC540, not the UC560.
The support parameters are very cut and dry now, I'm not sure when you last called on them, however there is no escalation path for any CLI, and the new stance is that if the feature does not exist in CCA, you should consider the feature doesn't exist on the platform. I have had this direct from the product and support teams. Also if you make CLI changes, your configuration is unsupported in its entirety.
I am very disappointed with this specifically, as we have been doing this for a long time, since UC520 was launched, and had clients on TAC support without these issues. We often need to use CLI for some of the most basic of features which are lacking in CCA.
What is truly upsetting is that they haven't put key features in CCA, then leave you out in the cold when you return to CLI in desperation. We are now looking at dropping the product entirely.
Hi Scott,
Mate I hear your frustration, it was actually a driving factor for me to
move on and try other challenges in my career, absolutely love the product,
but simply can't stand the decisions that have been made since August of
last year.
But I will continue to help people out on these forums because I hate
seeing people struggle with the product, especially when you can do so much
with it.
"History has proven time and time again, the path you chose must be
reinforced by sound decisions, enforcing a particular policy must be backed
up by something that is either equal to or better than what you are
replacing"
this forms part of any management decisions I make and what I tend to look
for with companies I work with.
Cheers,
David Trad
On Jun 2, 2012 10:23 PM, "smproductions" <
Hi David,
Couldn't agree more, and glad that it's not just me. You and I both know how powerful this product is, such a shame it is restricted by a weak GUI tool and a sub-standard support structure.
I was told "this is because so many of our partners had problems and lacked the skills required", so it looks like the sales people have won in this instance, and it is now UC for dummies. It used to be you needed some skills to implement and maintain these systems, but it's clear Cisco just want to move more units.
Cheers,
Scott
I ran into this problem as well.
We had a new customer that had existing subnets that overlapped with CUE's.
Cisco told us there was absolutely no way they could support a change to the service module IP.
Their recommendation was to tell the customer to re-address their whole network.
We ended up doing some wierd stuff to work around this, but have since gotten UCX certified to bypass all this nonsense.
Honestly if you are pretty experienced, I'd recommend going for the cert -- it's not too difficult. (Compared to many of the other Cisco certs anyway.)
Hi Daniel,
I would happily, however it is being retired and I have a month before the cert is no longer attainable. Not sure I have the time to study up on the 'Cisco way' to do the exams in a month, only to then find the cert will be retired in the short term, not to be replaced by anything.
http://www.cisco.com/web/partners/downloads/765/download/announcements/euc_announcement.pdf
Cheers,
Scott
J W
Thank you everybody for the info. Cisco ended up telling me the same thing. I am curious though, how people manage to get around the situation I am in.
As I've said, there are 2 locations each with a UC500 device. We are going to be doing the majority of the UC administration from one location, so things like going to 10.1.10.1 to upload a prompt, or even creating a user in CCA (Which interacts with CUE) will be challenging for the remote location (since all requests to 10.1.10.1 will go to the local UC).
How would I get around this?
Jared,
Unfortunately, you would probably need to set up some sort of remote desktop connection to the other site.  From there you would be able to get to the local CUE from that computer.
Hi Jared,
Well I guess you are going to have to bite the bullet, if the silly support
policy is not going to be flexible then you need to take matters in your
own hand.
The steps are as follows if you are willing to do CLI:
  • Session into the CUE module and change the IP address of the module, this
must be done first otherwise you will lock yourself out
  • Exit out of the session and get back to the CME command line, and proceed
to change the service module IP address
  • Make sure you change the Looback addresses as well, do not leave these as
the original ones
  • Go to your ACL and modify all CUE related entries to suit the new address
Do not write the memory on either the CUE or the CME until you know the
changes are completed and working.
Don't feel confident doing this yourself? Please engage a local partner and
get them to assist it will be much easier for you.
Cheers,
David Trad
On Jun 4, 2012 10:58 PM, "jarednwesley" <
