Slow download speeds on UC-540W wireless
Have a client with a UC540W with a 25MB/3MB Charter Internet connection.  Flow: Internet - ASA5505 - UC540
When directly connected to the switch which goes through the UC540W, they get regular 25MB download speeds.
When connected to the wireless, the speed drops significantly to around 6-7MB.
Have tried multiple different computers and getting the same results.  Any suggestions?  Running the latest SW Pack.
Helo Thomas,
The wireless is up to 54Mbps as it is 802.1 B/G module.
When you use 802.1G you get on all devices (this is the standard) up to 25 Mbps roughly as the wireless is not full duplex media in a way.
So this is the normal throughput.
HTH,
Alex
*Please rate helpful posts
EDIT: If you mean 25 Mbps dropped to 6-7 Mbps then maybe there is something else but should be considered that these 25 Mbps are between the users.
