04-21-2009 08:57 AM - edited 03-21-2019 01:03 AM
Does, this feature allow you to do for each extension you have in the system? This is similar to find-me n follow-me feature, right?
Solved! Go to Solution.
04-21-2009 09:19 AM
There are 2 options for SNR in SBCS:
Basic SNR - available in the 7.1.1EA (early adopter software pack) which allows for basic find me / follow me and is configurable per extension. More details here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html#wpxref40866
This feature will be configurable via CCA in the next release coming in the late May timeframe, today you can use CLI.
UCC Mobility - this is more advanced which has white lists / black lists etc along with find me / follow me. This is also configurable per extension and can be used with UC520 4.2.x or higher software pack
http://www.cisco.com/en/US/docs/voice_ip_comm/cucallconnectors/mobility_QRC.html
04-21-2009 10:00 AM
7.0 is not the latest package. There is an Early Adopter package for 7.1.
Follow this link.
https://supportforums.cisco.com/docs/DOC-9829
Accept the agreement.
The 7.1 EA is at the bottom.
04-21-2009 09:19 AM
04-21-2009 09:40 AM
so i can setup SNR for each extension, right?
04-21-2009 09:41 AM
Yes for both Basic and Advanced
04-21-2009 09:53 AM
i have cue 7.0 and my ios is uc500-advipservicesk9-mz.124-20.T2. the requirement to do SNR config has to be 7.1, so how do i make it to 7.1?
i believe my uc has the latest package.
04-21-2009 10:00 AM
Follow this link.
04-21-2009 11:02 AM
thank you i didn't see that one. thanks again...
