SPA112 Disable P-Station-Name Header
DavidK1
I'm attempting to register a SPA112 to our Alcatel OmniPCX enterprise PBX. When attempting to register the SPA112, the PBX returns a 501 Not Implemented.
Register message from SPA112:
    REGISTER sip:172.16.10.200 SIP/2.0
    Via: SIP/2.0/UDP 172.16.10.14:5059;branch=z9hG4bK-3266dc1e;rport
    From: <sip:249@172.16.10.200>;tag=55b03fd7916ad1fo0
    To: <sip:249@172.16.10.200>
    Call-ID: cef48bc7-f70550e1@172.16.10.14
    CSeq: 48784 REGISTER
    Max-Forwards: 70
    Contact: <sip:249@172.16.10.14:5059>;expires=120
    User-Agent: Cisco/SPA112-1.4.1_SR3
    P-Station-Name: ;mac=701f530b473f; display=""; sn=CCQ22250K14
    Content-Length: 0
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Supported: replaces
Reponse from PBX
    SIP/2.0 501 Not Implemented
    User-Agent: OXO030/055.001 GW_030/069.001
    To: <sip:249@172.16.10.200>;tag=0cd24ad1609d8af716047d9b3e247848
    From: <sip:249@172.16.10.200>;tag=cec30765ff78dad9o0
    Call-ID: 2b9b298d-e57eddd2@172.16.10.14
    CSeq: 44626 REGISTER
    Via: SIP/2.0/UDP 172.16.10.14:5059;received=172.16.10.14;branch=z9hG4bK-4d454a29;rport=5059
    Content-Length: 0
I can rule out the PBX not registering the account, as I'm able to connect via Linphone:
Via: SIP/2.0/UDP 172.16.10.60:5059;branch=z9hG4bK.pKox65dXU;rport
To: sip:249@172.16.10.200
CSeq: 20 REGISTER
Call-ID: c2iJZShg5K
Max-Forwards: 70
Supported: replaces, outbound
Accept: application/sdp
Accept: text/plain
Accept: application/vnd.gsma.rcs-ft-http+xml
Contact: <sip:249@172.16.10.60:5059;transport=udp>;+sip.instance="<urn:uuid:a1579d3f-ef78-4994-a785-afa7e20623ef>"
Expires: 600
User-Agent: Linphone Desktop/4.1.1 (belle-sip/1.6.3)
Which successfully responds with an unauthorized:
SIP/2.0 401 Unauthorized
WWW-Authenticate: Digest qop="auth",nonce="a3dc6b21a60b95a4d0c5d57f8fed266c",realm="172.16.10.200"
To: sip:249@172.16.10.200;tag=c93e2ac6b6a0773d8676fd57c43eeb86
Call-ID: c2iJZShg5K
CSeq: 20 REGISTER
Via: SIP/2.0/UDP 172.16.10.60:5059;received=172.16.10.60;branch=z9hG4bK.pKox65dXU;rport=5059
Content-Length: 0
Once authenticated I can go on to make calls, all of which work successfully. The SPA112 is unable to connect however.
Given that the differences in headers are minimal, I'm guessing that the PBX doesn't know what to do with the P-Station-Name. Is there a workaround or a way to disable the header from being sent in the REGISTER message?
Dan Lukes
Option Caller ID Header
Read documentation for details if necessary/interested.
i know this is quiet old , but by any chance you were able to disable the P-Station-Name ?
dan7837
None of the options of Caller ID Header affects P-Station-Name header in REGISTER , is there any way to remove it?
