SPA112 line showing as off hook with nothing connected
terryip83
Beginner
Beginner
I've got an ATA which will register, but Port 2 is always showing the Hook State as Off. There is currently nothing connected to the device apart from a network connection and a power supply. This behaviour still occurs after a reboot, a firmware upgrade and also a factory reset.
Phone 2 could be faulty.
You can check what happen using syslog but I suggest you to consider an RMA.
Regards.
6 Replies 6
Daniele Giordano
Collaborator
Collaborator
Is Phone 1 Port connected?
The issue occurs with either a phone connected or nothing connected to port 1. Both lines show as registered before the factory reset and port 1 functions as expected.
Regards.
I checked the syslogs for a working device and compared it to these units and there's virtually no difference between them. RMA it is then
Had the same problem with one of our SPA112's, except it was Phone 1 that was always off hook. Even after a factory reset, it remained off hook. Now it's a paperweight... and a lousy one at that.
Unplug cable from port 1.
Is the port still claimed "off hook" ? Port 1's SLIC is faulty or contacts in port 1 connector are shortened.
Is the port claimed "on hook" now ? Either cable or phone previously connected to port 1 are broken.
Recognize Your Peers
