07-22-2012 09:18 AM - edited 03-21-2019 09:49 AM
The firmware update upg-spa2102-5-2-13.exe doesn't work.
Error: Run-Time Check Failure #2 - Stack around the variable 'strNc' was corrupted.
Solution:
You have to remove (blank) the admin and user password before starting the update. Put them back after.
Only firmware 5.2.13 is affected.
11-17-2012 04:27 PM
Same here
Windows XP
SPA2102
Software Version:5.2.12
11-18-2012 05:10 PM
I'm getting the exact same error here, too.
Windows 7
SPA2102
Trying to upgrade from Version 5.2.12 to 5.2.13
01-11-2014 03:03 AM
Hi, where you able to apply the update to latest firmware? I go the exam same problem (C++ error blablabla... )
01-13-2014 12:51 AM
You can try a provisioning update method.
Enable a web server or tftp server on your PC (e.g. 3C Daemon), put the firmware file in the server directory and use one of these urls in your browser:
http://SPA_IP_ADDRESS/admin/upgrade?http://YOUR_WEB_SERVER_IP/SPA_FIRWARE.bin
or
http://SPA_IP_ADDRESS/admin/upgrade?tftp://YOUR_TFTP_SERVER_IP/SPA_FIRWARE.bin
Regards.
01-13-2014 04:34 PM
Solution:
