SPA301 - how make a factory reset?
010504oli
I wanna make a factory reset in my SPA301 any suggestion how to do that, thanks for your help.
ronpatel
Level 8
Level 8
Hi Ricardo,
You can do it via IVR present in the phone.
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf
Check section "Using IVR on the Cisco SPA301 and Cisco SPA501G IP Phone"
4—Factory Reset—Restores the phone to the factory default software
and settings. Enter 1 to confirm or * to cancel.
or you can use
https://supportforums.cisco.com/docs/DOC-14658
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
Hi Ricardo,
or you can use
Thanks for your answer, I solved going to
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/user/guide/spa300_sip.pdf
and the steps are sames that your content link, thanks for your help.
