SPA502G and 504G
AntalVincz
Hi All,
How to open pass locked, forgot admin pass SPA502G and 504G phones?
I try used the fw updater (spa50x-30x-7-6-1.exe), but don't work, it is also asking for a password.
Firmware update process clear the admin pass?
How to interpret this?
"If you are the administrator and forgot the password, you may perform a factory reset by entering ****, option 73738#, and value 1 from a telephone connected to the unit to be upgraded."
Thank you any help!
Tony
Luis Gradyz
Hello AntalVincz,
You're correct, according to the admin guide you need to enter the IVR menu by pressing the * (asterisk) button four times, then you will hear the IVR menu and you'll have to select any option by pressing its number and then #.
In order to do the reset you'll have to enter the IVR menu, then  press 3 (Other options) then 4 (Reset) and 1 to confirm or * to cancel.
Please bear in mind that some phones come pre-provisioned by the voice provider and thus some options may be blocked. Also, the firmware upgrade process will not clear the administrator password.
Have a great day!
Hi Luis,
Thanks for your answer.
When do pressing four times the * (star) button?
Before phone booted or after?
Please do you write the correct procedure, step-by-step.
Thank you
Tony
