09-28-2012 05:45 AM - edited 03-21-2019 06:21 AM
we have a very simple deployment of UC560 with 4 FXO lines with SPA504G phones. Users cannot tell if there's voicemail or not since the red light on the phones don't lit up nor an envelop icon show up on the phone... The notification on CCA is set to on... What else should we check to enable that?
Thanks in advance.
Solved! Go to Solution.
09-28-2012 08:59 AM
I think you have the same problem as https://supportforums.cisco.com/thread/2173437?tstart=0
I just answered it yesterday.
have a look it might help you
09-28-2012 08:59 AM
09-28-2012 09:18 AM
Thanks! it works.
