12-21-2009 10:20 AM - edited 03-21-2019 01:57 AM
It's possible to configura a line key 1 with an extended function like
fnc=blf+sd+cp;sub=200@172.18.20.22;nme=Ext 200
in order to monitor the extension 200 without an attendant Console?
I did it on an spa942 and spa962 but i don't know if it's possible on a SPA5XX
Thanks in advance
12-21-2009 10:32 AM
Dear Sir;
Yes, it is possible.
Alberto
12-21-2009 10:54 AM
I try it, but the led is all the time orange.
My Configuration is:
Extension: Disabled
Share Call Appearance: Shared
Extended Function: fnc=blf+sd+cp;sub=200@172.18.20.22;nme=Ext 200
Short Name: 200
Server Type: Asterisk
The Call Pickup and BLF doesn't work Speed Dial Works fine
Can you help me?
12-21-2009 03:12 PM
Hi cinglalls,
At asterisk's CLI, type: core show hints
This will tell you who is watching what
Verify that you've a hint in the extensions.conf file.
Example:
SPA509 has the following configuration to subscribe and monitor extension 508:
fnc=blf+sd+cp;sub=508@192.168.2.245;nme=508
The extensions.conf has the following:
exten => 508,1,Dial(SIP/508,10,rT) ;ring for 10 seconds
exten => 508,hint,SIP/508 ; hint: core show hints *CLI sees extension state
exten => 508,2,VoiceMail(508@default,u)
exten => 508,3,hangup
exten => 9508,1,VoiceMailMain(508) ;mailbox access for extension
Make sure that the sip.conf allows your phone to subscribe to extension 200's state. Continuing my example, sip.conf snippet:
; allow phone to subscribe to another phone's extension state
allowsubscribe=yes
notifyringing=yes
limitonpeer=yes
notifyhold=yes
Patrick
01-04-2010 09:57 AM
I put the other unused extensions to disabled and it works.
Thank's for your help.
03-04-2010 04:39 AM
I have a SPA504G and I'm trying to configure BLF with Elastix 1.6.
I can make a speed dial but the ligth is off.
08-12-2010 11:24 AM
FYI, I had the same type of problem (getting the last 4 line keys to be BLF+SD on a SPA509G), and disabling the unused lines did not help. It turned out the attendant console units were enabled in the config, but I did not have any SPA500S units attached. Disabling the two consoles in the config made BLF on the line keys work again.
