SPA525G2 - auto attendant possible?
nigel000111
Hi all,
Is there any way to have an auto attendant feature on the SPA525G2 without intervention from the telephony service provider?
We have a Billion 7800VDOX modem & 2x SPA525G2 phones connected via Ethernet.
mdobiac
Level 3
Level 3
Hello nigel000111,
As the phone does not manage the Auto Attendant (AA)itself you will need 1 of two things.
First:  Have your provider provide the AA feature (if they allow it)
Second:  Have a local Call control device to manage call routing.  (Example:  Asterisk, or BE 6000).
Though in your case I would contact your provider to see if they allow this feature.
Hope this helps.
Michael D.
Thanks Michael,
Unfortunately the telephone service provider does not offer auto attendant.
Is it easy to set this up on a BE6000?
Hello nigel000111,
I mostly used the BE6000 as an example as it is an Enterprise level device.  Here is the datasheet.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html
Otherwise an Asterisk server, that you'd manage yourself, or another provider that will offer that feature.
Michael D.
