SPA9000 + SPA400 = SPA502G msg SERVICE UNAVAILABLE
duettocisco
Hi guys,
I dont know why, only one of our 4 IP phones (SPA502G) shows:
'ServiceUnavailable'
'To: vmm'
When try to press voicemail button or try to dial '*97'.
Why?????????????? What happened?
My Environment
SPA9000 (Software Version: 6.1.5 / Hardware Version: 1.0.5)  = IP 192.168.1.10/24
SPA400 (Firmware Version: 1.1.2.2 with USB 120Mb key) = IP 192.168.1.5/24
SPA502G (Software Version: 7.4.7 / Hardware Version:  1.0.0(0001)) = DHCP
tks,
Renato Pereira
viewtekmsd
Hi Renato
If you used the setup wizard then reconfigure the phone in client stations through the wizard.
If that doesnt work back up the config and factory reset and try again.
The other thing to check is that you dial plan on the phone is set the same as the other handsets.
Hope this helps
Michael
5 Replies 5
duettocisco
I already did try to enable/disable user mailbox on SPA400/Setup/VoiceMailUsers >>>> Wthout success!
viewtekmsd
Hi Renato
Hope this helps
Michael
Hi Michael,
tks for reply; our customer found that SPA9000 cannot found SPA502 through the wizard and then manualy he set the phone field "Mailbox ID". Now it works!
* too many problems with theat wizard...
>>>> This case can be closed.
tks,
Renato P.
If you do not record 'grettings' for your mailbox, users cannot leave a message for you!!! It seems 'by design' in SPA400.
tks,
Renato P
In my vision, the SPA9000 Wizard is to struggle and confuse also!!!!!
>>>>>>>>>>>>>>>> Cisco team need create a new version more friendly and with more options!!!
