SPA9000 + SPA400 = SPA502G msg SERVICE UNAVAILABLE
duettocisco
Hi guys,
I dont know why, only one of our 4 IP phones (SPA502G) shows:
'ServiceUnavailable'
'To: vmm'
When try to press voicemail button or try to dial '*97'.
Why?????????????? What happened?
My Environment
SPA9000 (Software Version: 6.1.5 / Hardware Version: 1.0.5)  = IP 192.168.1.10/24
SPA400 (Firmware Version: 1.1.2.2 with USB 120Mb key) = IP 192.168.1.5/24
SPA502G (Software Version: 7.4.7 / Hardware Version:  1.0.0(0001)) = DHCP
tks,
Renato Pereira
viewtekmsd
Hi Renato
If you used the setup wizard then reconfigure the phone in client stations through the wizard.
If that doesnt work back up the config and factory reset and try again.
The other thing to check is that you dial plan on the phone is set the same as the other handsets.
Hope this helps
Michael
5 Replies 5
