08-31-2011 07:08 AM - edited 03-21-2019 04:35 AM
Hi gang,
Which document describes how to use analog phones on the UC320 FXS port(s). I.e. how transfer, park, hold calls, etc?
Thanks, Gary
Solved! Go to Solution.
08-31-2011 07:19 AM
Hi Gary,
You are looking for the UC320 Phone User Guide. You can find a link to all documentation on the UC320W Documentation document on this forum.
Cheers,
Chris
08-31-2011 07:19 AM
Hi Gary,
Cheers,
Chris
08-31-2011 07:21 AM
Yup, SPA300-500-UC320W_UG_78-19372.pdf page 70. Thanks.
01-02-2012 02:49 AM
Hi everybody ! I am french user and i want more information about FXS ports on UC320 ...
- In fact i want to transfer call from SPA504 phones to dect phone connect to the fxs port ...
- My dect phone functiun correctly i can call but i cant transfer to him
- When my dect phone call my SPA phone i see UNKNOWN as user and 200 with phone number .... My dect is number 102 normally ...
- Between IP Phones, no problem but when i try to call 102 or 200, the ip phone show that the remote phone is occuped...
Thank you i you have feedback in this problem i hace try the code *98 but the problem is the same ...
Pierre-Yves.
( PS : Will i have the same issue with spa8800 fxs ports ??? )
I have found another discussion where this is question to put a beta version .... With a modification of the PMF files ... version is 2.1.4(3) :
https://supportforums.cisco.com/message/3508225#3508225
We have the file and after the upgrade, the fxs is avaible to receive transfer nd more. Now how to make a function key to see if the fxs phone is free or occuped ?
