UC320W Install, Web GUI Will not load.
bndbrennan
I just purchased a UC320W, Did a factory reset, and try to access it via the default 192.168.10.1 address, and the blue cisco page loads (has cisco logo, and green bar), however, it never kicks over to the login page for me to start the configuration utility.
I have tried Chrome, FireFox, IE (All on Windows XP Pro, and Vista)
What could be wrong??
Also, I wish to use this setup for just 3 phones, and 4 computers, Can I just throw everything on a Cisco 3550 switch and have just one VLAN?
Thanks!
The version of UC320W may be not compatible with the Adobe Flash. There is a known incompatiblity with Adobe Flash Player 11 and UC320W  Configuration Utility running on firmware earlier than 2.1.2. Please check the following link to get the workaround.
https://supportforums.cisco.com/message/3478189#3478189
Best regards,
Wendy Yang
bndbrennan
I went to http://192.168.10.1/login.html/
Logged In Page Showed, I used "cisco" "cisco"
It brought me to
http://192.168.10.1/wizard/setupwizard.html
However, it is still the blue page with cisco logo.
Best regards,
Wendy Yang
Thank You!
Downgrading Flash Player Worked!
