12-07-2012 05:06 AM - edited 03-21-2019 06:42 AM
I Guys,
I have an issue with a UC520 (latest software pack).
The incoming number (for exemple: 32475XXXXXX) are not associated with the corresponding directory entry (exemple: directory entry 1 32475XXXXXX name jean).
The command service dnis dir-lookup is active in the telephony service but the name cannot display on the phone (only the incoming number)
Any ideas ?
Thanks.
Vincent.
12-07-2012 02:14 PM
Hi Vincent,
First of all this has been a long standing problems, however I would have thought that they would have resolved it by now with the new Software Packs and iOS upgrades, maybe not?
What software pack are you running on your UC-500 at present?
This once worked flawlessly right up until version 8 arrived, then it stopped working and it just never got better, I truly hope you can get this resolved as it is a very useful feature I must say.
Keep us posted, and please don't forget to log a case on this and bet someone from STAC to debug and assist.
Cheers,
David Trad
Sent from Cisco Technical Support Android App
12-07-2012 10:14 PM
Hello David,
Thanks for the reply.
Softwarepack: 8.6.1
IOS Image: uc500-advipservicesk9-mz.151-4.M5
CME Version: 8.6
Voicemail version: 8.6.5
My UC520 is an older one but I have the same issue with a brand new UC540 on a customer site.
In a first time I think it was a problem because the incoming number are from a SIP trunk.
But on my customer site, the incoming number are from PSTN and the problem is the same.
Perhaps it's the CCA configuration...
Regards.
Vincent
12-09-2012 07:27 PM
I'm having the same issue on a UC540 on a customer site with SIP trunks only. Posting here to see if I can give any data that can help.
12-13-2012 06:46 AM
Remove calling name using SIP profile.
That will enable CME directory lookup.
12-14-2012 04:39 AM
Hello Paolo,
Thanks for your reply.
I can't see the calling name option in the sip profile.
This is the sip profile:
registrar server expires max 3600 min 3600
no update-callerid
sip-profiles 1000
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
Thanks for your help.
Vincent.
12-14-2012 01:35 PM
Details for configuring SIP profile need to be seen and handled on a case-by-case basis.
