UC520 MOH Problems
Jaswild999
I have been browsing the internet and Cisco support forums (among others) trying to find help.  I am trying to take an MP3 file and create the appropriate AU file for MOH.  I have downloaded Audacity from SoundForge to attempt this with no luck.  I am trying to get the 8-bit 8-khz file and everytime I load it and test, it just sounds like static.
I have through the following forums in my searches:
https://communities.cisco.com/message/17431
https://communities.cisco.com/thread/1657
https://supportforums.cisco.com/thread/313246
http://uc500.com/en/moh-music-hold
http://uc500.com/en/music-hold-issues
I've configured codecs, buffer, gain, etc.  I don't even know at this point if I've configured the AU file appropriately.
Anyone out there that would be willing to give me some pointers or has had the same tough time I am having with this?  Let me know what other information I need to provide.
Jason
3 Accepted Solutions
Hello Jason,
Here is a link for MoH settings:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wpxref70473
If you still have problems, just let me know, and I can convert the file for you.
Thank you,
Darren
Jason,
Sent you a Private Message...
Thank you,
Darren
Hello all,
Here are the steps I followed using Audacity (2.0.1)
*  File > open – choose the .mp3 file you want to use.
*  Change the track by choosing “split stereo to mono”.  (Use down arrow on the track to find this option.)
*  You will now have 2 tracks shown.  Click “x” to remove/close top track.
*  Change Project Rate in the bottom left corner to 8000Hz.
*  Click “File” > “export”. Change “Save as type” to “Other uncompressed files”.
*  Click on “Options” button on the right side.
     *  Header = AU (Sun/NeXT)
     *  Encoding = U-Law
*  Enter a file name – newmoh.au
*  Change Metadata if desired, otherwise just click on “OK”.
Now you should be able to load that file onto your UC500 to use for Music-on-Hold.
If using CCA, load file to "media" directory, and the new MoH file will show up in CCA for you to use.
Thank you,
Darren
8 Replies 8
paolo bevilacqua
Actually sample size should be 16 bits, mono.
That is what I have tried
Hello Jason,
Thank you,
Darren
Darren,
I've gone through most of that, still no dice.  I believe it's the manner in which the file is being saved.  I've tried using 16bit, mono using Audacity.  I've saved .WAV and .AU files, but unable to get either to work.
Jason
David Trad
Hi Jason,
Are you saving this as a uLaw file?
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Jaswild999
I don't know if it matters, but I've been uploading the file via TFTP to the system.  I will also use CCA to enable MOH.  I have not gone too deep into the settings.  I'm on-site with customer now, so i'll give it a shot and play with the MOH file I'm trying to create.
regards,
jason
Jason,
Thank you,
Darren
Hello all,
     *  Encoding = U-Law
Thank you,
Darren
