UC520# squeeze flash: command does not exist - need help
pbanholzer
Hi all,
I'm having some trouble with a UC520. After updating, deleting and  uploading phoneloads to the flash: memory it is almost full. (But there  should be more space available.)
When I use the command show flash: or dir /all /recursive flash: the  UC500 tells me there is 4.505.600 bytes available (123.678.720 bytes  used) of my 128M flash-card. But when I sum the filesizes of the single  files this is only 64.543.836 bytes so there should be at least 60Mbytes  free.
After some research I think the problem is, that the flash is fragmented or the files where not propperly / fully deleted.
To solve this problem Cisco offers the squeeze command. But this command doesn't exist on the UC. Do you have any suggestions how to solve this problem?
- Patrick
Wow. I have no clue what those are.
I suppose you could back them up and get them off. Perhaps after a few searches on ' orphans on iOS flash'
11 Replies 11
paolo bevilacqua
The command doesn't exist on current products because is used only on older non-FAT filesystems.
Try fsck .
I tried fsck flash:
command works but there is not more free space ... also reloaded the UC.
UC520#fsck flash:
Starting File System integrity check
NOTE: File System will be deinited and later rebuilt
Partition Table check ...[Passed]
Starting partition 0 Analysis
    Boot Sector/Boot Parameter Block check ...[Passed]
    DIB not present
    DIB & Monlib check ...[Passed]
    Partition Init check ...[Passed]
    Directory entries check ...[Passed]
Rebuilding the file system
fsck of flash: complete
UC520#
any other idea?
Have you/your users a lot of greetings/messages. You can check in CCA how many minutes each mailbox has.
As far as I know the greetings and messages are stored on the flash but you wont see them as WAV files.
UC520 IOS Flash is 128M externally mounted and the biggest user of space on it is phone loads. You do not need all the phone loads if you don't have then plugged in. Some oh them are 7M themselves (just one) for example.
CUE flash is internal and separate from IOS flash, so voice mail storage doesn't exist on IOS flash.
The UC540 has 256M IOS flash as does the UC560.
i thought the CUE of the UC520 (Not 540/560) uses the same flash as the CME part of the UC.
I know i don't need all the phoneloads - but I have connected a 7942, 7962, 7965, 7916(exp), 7911, SPA504, SPA525 and SPA303
so I need the phoneloads: 7942_7962, 7945_7965, SPA30X_SPA50X, SPA525, 7916 and I dont have enough space for all of them.
Nope. Separate flash.
Are you using CCA 3.0?
There is the file upload / Download from UC 500 iOS flash to your PC option.
There is also a Phone Load Manager utility to confirm what you have and can remove or add phone loads.
There must be something else there. While ALL the phone loads won't fit on a UC520 (this is clear), a few of them should. Are you using flash for CDRs or Reports? Do you have old IOS images you don't need?
Yes, using CCA3.0.
shure i have checked with the filemanager and I uploaded and deleted the phoneloads via PhoneLoad management in CCA.
But I think I found the problem. I just used "show flash:" command again and now there are some more entries. the ORPHAN1/* files where not there before. Can i just delete them? (See output below) Maybe these files where not visible before issuing the "fsck flash:" command
UC520#show flash:
-#- --length-- -----date/time------ path
1          780 Dec 28 2010 14:54:38 vlan.dat
2     39404784 Dec 28 2010 14:26:52 uc500-advipservicesk9-mz.151-2.T2
3            0 Dec 28 2010 14:26:56 phones
4            0 Dec 28 2010 14:26:56 phones/521_524
5       892511 Dec 28 2010 14:27:04 phones/521_524/cp524g-8-1-17.bin
6            0 Jan 13 2011 12:07:46 phones/50x-30x
7      3859574 Jan 13 2011 12:08:16 phones/50x-30x/spa50x-30x-7-4-6.bin
8            0 Jan 13 2011 12:07:48 phones/7942_7962
9      2936005 Jan 13 2011 12:08:36 phones/7942_7962/apps42.8-5-4TH1-6.sbn
10      524894 Jan 13 2011 12:08:42 phones/7942_7962/cnu42.8-5-4TH1-6.sbn
11     2102234 Jan 13 2011 12:08:56 phones/7942_7962/cvm42sccp.8-5-4TH1-6.sbn
12      342219 Jan 13 2011 12:09:02 phones/7942_7962/dsp42.8-5-4TH1-6.sbn
13     1756328 Jan 13 2011 12:09:16 phones/7942_7962/jar42sccp.8-5-4TH1-6.sbn
14         670 Jan 13 2011 12:09:18 phones/7942_7962/SCCP42.8-5-4S.loads
15         674 Jan 13 2011 12:09:20 phones/7942_7962/term42.default.loads
16         674 Jan 13 2011 12:09:22 phones/7942_7962/term62.default.loads
17           0 Jan 13 2011 12:07:50 phones/7945_7965
18     2936005 Jan 13 2011 12:09:40 phones/7945_7965/apps45.8-5-4TH1-6.sbn
19      525007 Jan 13 2011 12:09:48 phones/7945_7965/cnu45.8-5-4TH1-6.sbn
20     2103813 Jan 13 2011 12:10:04 phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn
21      342219 Jan 13 2011 12:10:08 phones/7945_7965/dsp45.8-5-4TH1-6.sbn
22     1882934 Jan 13 2011 12:10:22 phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn
23         650 Jan 13 2011 12:10:24 phones/7945_7965/SCCP45.8-5-4S.loads
24         654 Jan 13 2011 12:10:26 phones/7945_7965/term45.default.loads
25         654 Jan 13 2011 12:10:28 phones/7945_7965/term65.default.loads
26           0 Jan 13 2011 12:11:26 phones/7916
27      166179 Jan 13 2011 12:11:32 phones/7916/B016-1-0-4.SBN
28       21716 Dec 28 2010 14:31:40 UC520-8U-2BRI-K9-factory-8.1.0.cfg
29           0 Dec 28 2010 14:30:06 autoattendant
30       94503 Dec 28 2010 14:30:08 autoattendant/AA_SBCS_v01.aef
31       96166 Dec 28 2010 14:30:08 autoattendant/AA_SBCS_v02.aef
32      130488 Dec 28 2010 14:30:10 autoattendant/AA_SBCS_v03.aef
33       15891 Dec 28 2010 14:30:10 autoattendant/AA_transfer.aef
34           0 Dec 28 2010 15:14:34 its
35         102 Dec 28 2010 15:15:46 its/SEPDEFAULT.cnf
36        4209 Jan 13 2011 12:11:34 its/XMLDefault.cnf.xml
37        1583 Dec 28 2010 15:15:46 its/XMLDefault7971-7914-1.cnf.xml
38        1421 Dec 28 2010 15:15:46 its/XMLDefault7971.cnf.xml
39        1583 Dec 28 2010 15:15:48 its/XMLDefault7971-7915-12-1.cnf.xml
40        1143 Dec 28 2010 15:17:02 its/SEP0013C4B18173.cnf.xml
41        1650 Jan 14 2011 09:06:48 its/SEP0021A0856DD8.cnf.xml
42        1583 Dec 28 2010 15:15:48 its/XMLDefault7971-7915-24-1.cnf.xml
43        1583 Dec 28 2010 15:15:48 its/XMLDefault7971-7916-12-1.cnf.xml
44        1650 Jan 14 2011 09:06:48 its/SEPACA0166F6390.cnf.xml
45        1822 Jan 14 2011 09:06:50 its/SEP0022905A58B9.cnf.xml
46        1583 Dec 28 2010 15:15:50 its/XMLDefault7971-7916-24-1.cnf.xml
47        1583 Dec 28 2010 15:15:50 its/XMLDefault7971-500S-1.cnf.xml
48         540 Dec 28 2010 15:15:50 its/ATA04FE7F69CC30.cnf.xml
49         540 Dec 28 2010 15:15:50 its/ATAFE7F69CC3001.cnf.xml
50        1714 Dec 28 2010 15:15:50 its/XMLDefault7971-7914-2.cnf.xml
51        1714 Dec 28 2010 15:15:52 its/XMLDefault7971-7915-12-2.cnf.xml
52        1480 Jan 14 2011 09:06:50 its/SEPD0D0FDE964DC.cnf.xml
53         903 Jan 14 2011 09:06:50 its/united_states_7960-tones.xml
54        1714 Dec 28 2010 15:15:52 its/XMLDefault7971-7915-24-2.cnf.xml
55        1714 Dec 28 2010 15:15:52 its/XMLDefault7971-7916-12-2.cnf.xml
56        1650 Jan 14 2011 09:06:48 its/SEPACA0166FBEA2.cnf.xml
57        1714 Dec 28 2010 15:15:54 its/XMLDefault7971-7916-24-2.cnf.xml
58        1496 Jan 14 2011 09:06:50 its/SEP1CDF0F4B22EA.cnf.xml
59        1714 Dec 28 2010 15:15:54 its/XMLDefault7971-500S-2.cnf.xml
60       32040 Jan 14 2011 09:06:04 its/user_define_4_521-dictionary.xml
61       32040 Jan 14 2011 09:06:06 its/user_define_4_524-dictionary.xml
62       79126 Jan 14 2011 09:06:06 its/user_define_4_525G-dictionary.xml
63        8777 Jan 14 2011 09:06:52 its/united_states_7960-font.xml
64        1313 Jan 14 2011 09:06:52 its/united_states_7960-kate.xml
65       19750 Jan 14 2011 09:06:52 its/united_states_7960-dictionary.xml
66        2740 Jan 14 2011 09:06:52 its/united_states_SCCP-dictionary.xml
67     1242624 Dec 28 2010 15:16:14 its/CME-locale-de_DE-German-8.1.2.1.tar
68       50843 Jan 14 2011 09:06:02 its/user_define_4_504-dictionary.xml
69       50843 Jan 14 2011 09:06:04 its/user_define_4_508-dictionary.xml
70       50843 Jan 14 2011 09:06:04 its/user_define_4_509-dictionary.xml
71        1327 Jan 14 2011 09:06:06 its/user_define_4_525G-kate.xml
72        1096 Jan 14 2011 09:06:08 its/user_define_4_525G-tones.xml
73       79126 Jan 14 2011 09:06:08 its/user_define_4_525G2-dictionary.xml
74        1327 Jan 14 2011 09:06:08 its/user_define_4_525G2-kate.xml
75        1096 Jan 14 2011 09:06:10 its/user_define_4_525G2-tones.xml
76        1863 Jan 14 2011 09:06:12 its/user_define_4_7921-kate.utf-8.xml
77        1806 Jan 14 2011 09:06:12 its/user_define_4_7921-kate.xml
78       26885 Jan 14 2011 09:06:10 its/user_define_4_7905-dictionary.xml
79       20815 Jan 14 2011 09:06:14 its/user_define_4_7960-dictionary.xml
80        1327 Jan 14 2011 09:06:14 its/user_define_4_7960-kate.xml
81       59216 Jan 14 2011 09:06:10 its/user_define_4_7921-dictionary.xml
82       61913 Jan 14 2011 09:06:18 its/user_define_4_ipc-sccp.jar
83       61653 Jan 14 2011 09:06:18 its/user_define_4_mk-sccp.jar
84        2815 Jan 14 2011 09:06:20 its/user_define_4_tags_file
85        1096 Jan 14 2011 09:06:14 its/user_define_4_7960-tones.xml
86       69770 Jan 14 2011 09:06:20 its/user_define_4_rp-sccp.jar
87        2907 Jan 14 2011 09:06:20 its/user_define_4_SCCP-dictionary.xml
88         688 Jan 14 2011 09:06:16 its/user_define_4_CME-locale-de_DE-German-8.1.2.1.tar.cfg
89      137616 Jan 14 2011 09:06:12 its/user_define_4_7921-font.dat
90       61838 Jan 14 2011 09:06:16 its/user_define_4_be-sccp.jar
91        1386 Jan 14 2011 09:06:16 its/user_define_4_g3-tones.xml
92       74885 Jan 14 2011 09:06:18 its/user_define_4_gp-sccp.jar
93       71712 Jan 14 2011 09:06:22 its/user_define_4_tc-sccp.jar
94       61913 Jan 14 2011 09:06:22 its/user_define_4_td-sccp.jar
95        2763 Jan 14 2011 09:06:22 its/user_define_4_utf8_tags_file
96        8777 Jan 14 2011 09:06:14 its/user_define_4_7960-font.xml
97       50843 Jan 14 2011 09:06:02 its/user_define_4_501-dictionary.xml
98       50843 Jan 14 2011 09:06:02 its/user_define_4_502-dictionary.xml
99           0 Dec 28 2010 14:30:20 cca
100        845 Dec 28 2010 14:30:20 cca/Key_Phoneloads.csv
101     113875 Dec 28 2010 14:30:20 cca/sccpphoneloadstable.csv
102        375 Dec 28 2010 14:30:22 cca/UC500_CCA_Dir_8.0.2.txt
103          0 Dec 29 2010 17:22:44 applications
104          0 Dec 29 2010 17:22:44 applications/faxmail
105          0 Dec 29 2010 17:22:46 applications/faxmail/custom
106      24475 Dec 29 2010 17:22:58 applications/faxmail/app_fax_detect.2.1.2.2.tcl
107       5101 Dec 29 2010 17:23:12 applications/faxmail/app_faxmail_offramp.2.0.1.1.tcl
108      12268 Dec 29 2010 17:23:24 applications/faxmail/app_faxmail_onramp.2.0.1.3.tcl
109      56700 Dec 29 2010 17:23:38 applications/faxmail/en_listen_first.au
110      81404 Dec 29 2010 17:23:50 applications/faxmail/ch_listen_first.au
111      83092 Dec 29 2010 17:24:04 applications/faxmail/sp_listen_first.au
112          0 Dec 28 2010 14:30:32 gui
113       3987 Dec 28 2010 14:30:32 gui/admin_user.html
114     677820 Dec 28 2010 14:30:36 gui/admin_user.js
115       1029 Dec 28 2010 14:30:38 gui/CiscoLogo.gif
116        635 Dec 28 2010 14:30:38 gui/CME_GUI_README.TXT
117        953 Dec 28 2010 14:30:38 gui/Delete.gif
118      16344 Dec 28 2010 14:30:38 gui/dom.js
119        864 Dec 28 2010 14:30:40 gui/downarrow.gif
120       6146 Dec 28 2010 14:30:40 gui/ephone_admin.html
121       4558 Dec 28 2010 14:30:40 gui/logohome.gif
122       3866 Dec 28 2010 14:30:40 gui/normal_user.html
123      78428 Dec 28 2010 14:30:42 gui/normal_user.js
124       1347 Dec 28 2010 14:30:42 gui/Plus.gif
125          0 Dec 28 2010 14:30:42 gui/sn
126      11513 Dec 28 2010 14:30:42 gui/sn/handshake.html
127     633459 Dec 28 2010 14:30:46 gui/sn/handshake.swf
128        843 Dec 28 2010 14:30:46 gui/sxiconad.gif
129        174 Dec 28 2010 14:30:48 gui/Tab.gif
130       2432 Dec 28 2010 14:30:48 gui/telephony_service.html
131        870 Dec 28 2010 14:30:48 gui/uparrow.gif
132       9968 Dec 28 2010 14:30:48 gui/xml-test.html
133       3412 Dec 28 2010 14:30:50 gui/xml.template
134      40167 Dec 28 2010 15:11:32 startup-config.bak
135          0 Jan 14 2011 08:58:26 ORPHAN1
136     540672 Jan 14 2011 08:58:26 ORPHAN1/orphan_1
137    1830912 Jan 14 2011 08:58:26 ORPHAN1/orphan_2
138       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_3
139       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_4
140       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_5
141    2936832 Jan 14 2011 08:58:26 ORPHAN1/orphan_6
142     528384 Jan 14 2011 08:58:26 ORPHAN1/orphan_7
143    2105344 Jan 14 2011 08:58:26 ORPHAN1/orphan_8
144     344064 Jan 14 2011 08:58:26 ORPHAN1/orphan_9
145    1888256 Jan 14 2011 08:58:26 ORPHAN1/orphan_10
146       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_11
147       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_12
148   10362880 Jan 14 2011 08:58:26 ORPHAN1/orphan_13
149      53248 Jan 14 2011 08:58:26 ORPHAN1/orphan_14
150     147456 Jan 14 2011 08:58:26 ORPHAN1/orphan_15
151     167936 Jan 14 2011 08:58:26 ORPHAN1/orphan_16
152    8097792 Jan 14 2011 08:58:26 ORPHAN1/orphan_17
153     131072 Jan 14 2011 08:58:26 ORPHAN1/orphan_18
154       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_19
155     708608 Jan 14 2011 08:58:26 ORPHAN1/orphan_20
156     131072 Jan 14 2011 08:58:26 ORPHAN1/orphan_21
157    2936832 Jan 14 2011 08:58:26 ORPHAN1/orphan_22
158     503808 Jan 14 2011 08:58:26 ORPHAN1/orphan_23
159    2105344 Jan 14 2011 08:58:26 ORPHAN1/orphan_24
160     540672 Jan 14 2011 08:58:26 ORPHAN1/orphan_25
161    1630208 Jan 14 2011 08:58:26 ORPHAN1/orphan_26
162       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_27
163       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_28
164       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_29
165    2936832 Jan 14 2011 08:58:26 ORPHAN1/orphan_30
166     528384 Jan 14 2011 08:58:26 ORPHAN1/orphan_31
167    2105344 Jan 14 2011 08:58:26 ORPHAN1/orphan_32
168     344064 Jan 14 2011 08:58:26 ORPHAN1/orphan_33
169    1757184 Jan 14 2011 08:58:26 ORPHAN1/orphan_34
170       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_35
171       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_36
172       4096 Jan 14 2011 08:58:26 ORPHAN1/orphan_37
173    2936832 Jan 14 2011 08:58:26 ORPHAN1/orphan_38
174     528384 Jan 14 2011 08:58:26 ORPHAN1/orphan_39
175    2105344 Jan 14 2011 08:58:26 ORPHAN1/orphan_40
176     344064 Jan 14 2011 08:58:26 ORPHAN1/orphan_41
177    1884160 Jan 14 2011 08:58:28 ORPHAN1/orphan_42
178       4096 Jan 14 2011 08:58:28 ORPHAN1/orphan_43
179       4096 Jan 14 2011 08:58:28 ORPHAN1/orphan_44
180       4096 Jan 14 2011 08:58:28 ORPHAN1/orphan_45
181    2936832 Jan 14 2011 08:58:28 ORPHAN1/orphan_46
182     503808 Jan 14 2011 08:58:28 ORPHAN1/orphan_47
183    2105344 Jan 14 2011 08:58:28 ORPHAN1/orphan_48
184          0 Dec 28 2010 14:31:14 sn
185          0 Dec 28 2010 14:31:16 sn/status
186          0 Dec 28 2010 14:31:16 sn/tmp
4501504 bytes available (123682816 bytes used)
UC520#
ok - we have a solution
this works:
fsck flash:
show flash: (identify the ORPHAN directory)
delete /recursive /force flash:/ORPHAN1
reload
have 63Mbyte free flash now.
Nice Job!!!!!!!!!!!!!!!!
This UC520 is used in an testing environment so the mailboxes are all empty.
