UC520 with SPA942
damir4a10
Can anybody help me, with this:
I have UC520 and bunch of SPA 942 phones. How make them work? And is it possible at all?
Best regards,
Damir
Hello Damir,
The SPA900 phones are only compatible with SIP, so you would have to configure SIP on the UC in order to register the SPA942 phones.
Please refer to this post for some sample SIP configurations: https://supportforums.cisco.com/message/3330441
-john
johschaf
Level 4
Level 4
Hello Damir,
Unfortunately, the SPA900 series phones are not supported with the UC500 platform.
You can find information regarding supported phones at the following links:
https://supportforums.cisco.com/docs/DOC-9827
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_2_1/release/Notes/cca_3_2_1_relnotes.html#wp311445
-john
John,
Thank you very much for your answer.
Yes you are right, UC500 series are not oficially supported. The problem is - we already have UC520 and phones, so we have nothing to lose. With all this in mind, I wonder may be someone had experience to make it work with some sort of custom firmware or... you know
Hello Damir,
-john
John,
Thanks a lot! That link is what we need. I hope configuration examples will help us
Best regards,
Damir
